Does anyone know how to adjust the rev limit on my warrior ? It seems to cut back around 4500 rpm. I have a pc iii . bak kit and big shots and it won't rev any higher . thanks
stock ecu has the rev limiter cut in at 5200rpm. There is no way to change this. If you are getting a flat spot at 4500rpm would sugguest looking for a new map for your pcIII. With a proper map you should get full power right up to 5000rpm before it starts to drop off. check out the maps to have in the library section for one that matches you settup.
A rev limiter at 5200? When I was mapping my PCIII, I got the revs up to 5500 at wide open open throttle.
Related Threads
RS Warrior Forum
posts
1.6M
members
38K
Since
2002
