Hey guys, I'm looking for any leads as to where I can source a longer bolt for the right hand mirror. I'm on my second set of aftermarket mirrors and love the new ones, but the bolt that came with them is just long enough to put the mirror on. I want to get a bolt about 3/4 of an inch or say 18-20mm longer so I can put a spacer under the mount and get the mirror to where I want it. I have no luck with YAMAHA or any of the local bike shops, I have tried calling or going to just about every Hardware shop/Industrial supplier in central MA. No luck on Reverse thread metric stuff. I tried to source a die so i could make one and had no luck with that either. If anyone has found these Mystery bolts anywhere please speak up. Also if anybody knows or can measure the pitch of the stock mirror or adaptor they are using, please post it.
I also tried the spacer and bolt from my old set of YAMAHA tear drops, same basic issue, not enough threads to hold it on. I tried Blue locktite, let it cure, it vibrated loose after a mile. There just isn't enough threads to do the job.
Thanx in advance. Dave
