1 - 3 of 3 Posts
I need a set of Riser Bolt Sleeves (Spacers)to be able to mount my new bars. The bolts are too small of a diameter for the stock tree holes. I used to have a set of these sleeves, when I had my Yamaha Billet Handlebar Risers.
They are 1-7/16" (36.5 mm) Long, 17/32" (13.4874 mm) OD, and 13/32" (10.3124 mm) ID.
Does anyone have a set? Can anyone make a set?
As i recall the2-risersleeves supplied by Yamahaare 14mm OD x 12mm ID x 35mm approx to fit inside the 14mm riser bushings and over the M12 riser bolts. Here are some options listed below:
AlanH said:
Stock Risers thread size?
Fri, Dec 28 2007 12:58 PM
Here's a possible solution if you go with the M12 riser bolts: IMHO loose fitting riser bolts will contribute to handlebar vibration
Check these threads:
http://rswarrior.com/forums/p/13478/100857.aspx#100857
http://rswarrior.com/forums/p/13478/211192.aspx#211192
http://rswarrior.com/forums/p/13478/211201.aspx#211201
http://rswarrior.com/forums/p/13478/211202.aspx#211202
Here's some more info using this query: http://rswarrior.com/search/SearchResults.aspx?q=sleeves+AND+userid%3a5646&o=Relevance
1 - 3 of 3 Posts
