Road Star Warrior 1700 belt drive spec's
9.6K views 16 replies 11 participants last post by  Churchkey
Hi
Does anyone have the belt width for the Road Star Warrior 1700? Also, the measurement from the front pully to the rear. (center to center) Lastly, belt tooth change. ie: 1 tooth one belt moves rear axle .280 or one tooth change on pully moves axle .280. Are longer belts availabe for these units? I know that's a lot of questions however if there was a dealer close I could try and get this but I'm afraid I'm a bit out in the boonies!
#7 ·
quote:Originally posted by Balaboy
What does oem stand for anyway EH?
Well it could stand for:
Occupational and Environmental Medicine
Operating Expenses & Maintenance
Office of Emergency Management
Oracle Enterprise Manager
Oregon Emergency Management
Object Exchange Model
Operations, Engineering & Maintenance
Orange Engineering & Machine Company, Inc. (manufacturer of hydraulic presses and vacuum lamination presses for the printed circuit board industry)
Ontology Engineering & Management
Open-Ended Mathematics
Order Entry Module
One Europe Magazine (Association des Etats Généraux des Etudiants de l'Europe)
On-Equipment Material
Old Economy Model
Overtime Eligible Manager
Oilfield Electric Marine
Onde Electro-Magnétique (French: Electromagnetic Wave)
Old English Mastiff
One Eyed Monster
But in this context it stand for Original Equipment Manufacturer,..... Eh. [/emoticons/emotion-5.gif]
#8 ·
quote:Originally posted by Warrior1oz
The belt you are looking for is 1 1/8", 133 tooth, 14mm pitch, and yes you can get them with more or less teeth, ie shorter or longer. Check out Phatperformance.com and he has two brands and lots of choices.
Hi Warrior1oz. Phatperformance.com seems to be a link site with a number of affiliates and annoying popups. Do you know which links has the belts? Now that I know the pitch is 14mm, I need one with 150 teeth. Thanks!
#11 ·
quote:Originally posted by centurian
I have not seen a 1 1/8" belt with that many teeth, maybe someone makes one, Gates poychain only goes to 139"
The only one I can find centurian is for a V-Rod. It's 1.50 wide, 150 teeth. Wrote to Gates to see if they can narrow a couple up for me. Thanks guys, nice forum here.
#15 ·
quote:Originally posted by Churchkey
You could use a Road Star 1.5 front & rear pulley. Or a rear pulley from a 99 & earlier Harley. I have the Harley rear pulley if your interested.
Thanks Churchkey
I need to stick with the narrower belt. About the best solution I can come up with is to have (or cut myself) the V-Rod belt. I'm told it will stay strong enough.
#16 ·
Order Entry Module
Old Economy Model
Old English Mastiff
One Eyed Monster
Dude you've got waaaaay too much time on your hands
