1 - 8 of 8 Posts
I have to get the tranny recall done, can anyone tell me what gear or gears I need for the upgrade. The dealer here has done a lot of the recalls but has no idea on the gear upgrade. Thanks for your help!
Here maybe?
http://www.motorsportssuperstore.com/fiche_section_detail.asp
Must be on this list? Ah what the **** do I know..[:I]
AXLE, MAIN
4WM-17411-A0-00 (replaces 4WM-17411-00-00) 1 $110.50
GEAR, 4TH PINION
5JA-17141-00-00 1 $46.18
WASHER,SPEC'L SHAP
90209-25196-00 1 $2.60
CIRCLIP,OUTER
93440-28062-00 1 $2.82
GEAR,2ND PINION
4NK-17121-01-00 1 $89.90
GEAR,5TH PINION
4NK-17151-00-00 1 $62.03
CIRCLIP,S-TYPE
93410-23056-00 1 $1.18
WASHER,PLATE
90201-232K5-00 1 $4.24
BEARING
93306-37806-00 1 $30.57
BEARING
93306-30441-00 1 $20.85
AXLE, DRIVE
4WM-17421-00-00 1 $108.81
GEAR,5TH WHEEL
4NK-17251-00-00 1 $76.84
GEAR,2ND WHEEL
4NK-17221-01-00 1 $68.88
WASHER,SPEC'L SHAP
90209-32231-00 1 $3.62
CIRCLIP,OUTER
93440-34025-00 1 $3.58
GEAR,3RD WHEEL
4NK-17231-01-00 1 $64.86
WASHER,SPEC'L SHAP
90209-27192-00 1 $2.82
CIRCLIP,OUTER
93440-30077-00 1 $2.14
GEAR, 4TH WHEEL
4NK-17241-02-00 (replaces 4NK-17241-01-00) 1 $54.87
GEAR,1ST WHEEL
4NK-17211-01-00 1 $80.25
WASHER,PLATE
90201-256K6-00 1 $2.55
CIRCLIP,S-TYPE
93410-25017-00 1 $1.37
BEARING
93306-20550-00 1 $31.48
BEARING
93305-20607-00 1 $50.59
COLLAR
90387-3015P-00 1 $15.34
O-RING
93210-30660-00 1 $2.38
OIL SEAL
93103-38184-00 1 $15.85
wilsons96, It is the 5th gear set for the regular roadstar. It is a higher ratio, so it gives a lower rpm for a given speed on the highway.
When I had my recall done, I didn't do that and wish I had.
Your dealer should be able to order it when he orders the recall kit. It is my feeling that you are better letting the dealer order the parts. Most dealers aren't happy installing parts, for nothing, that were bought from someone else.
Check here:
http://rswarrior.com/forums/topic.asp?TOPIC_ID=14583&SearchTerms=5th+gear
I ordered these:
4NK-17151-00-00 GEAR,5TH PINION
4NK-17251-00-00 GEAR,5TH WHEEL
quote:Originally posted by ridingrules
Check here:
I ordered these:
This the one I order..[8D]
Just picked up my bike yesterday from the recal work. Had the 5th gear upgrade and HC stock bore PR pistons[/emoticons/emotion-2.gif]
The gear upgrade is a great mod...oh and the pistons too[}/emoticons/emotion-1.gif]
1 - 8 of 8 Posts
