1 - 3 of 3 Posts
Yes however the shoulder on the rear rotor bolts will now be to long to reuse them you will need either front rotor bolts or do what I did & add stainless steel washers to the original bolts.
That is a supposed heat-sink to disperse rotor heat, but many have removed it. A search will yield the needed shorter fastener if removed.
Adding: stock rear bolts are part number 90109-06049 but because its a shoulder bolt the part number is unlikely to code the bolt dimensions so you would need to remove to match, or buy fronts (90109-064G6). Notice the stock front bolts have a small shoulder to match the rotor mount holes. I presume its a match to the back bolt shoulder diameter since others have used them in this mod. Separate from that, I do not know what size stainless washers have been used by others here to make-up the distance needed in order to re-use the rear bolts without the cover. I see Church posted a moment before my original post. Great info.
1 - 3 of 3 Posts
