I just replaced a Barons BAK with a PR BAK with velocity stacks. Could this change cause it to run lean? After the change I started getting some engine vibration at around 3000 rpm that is especially noticeable in 5 gear. I was thinking about bumping up the fuel in the mid and high range. Any suggestions? I have a PCIII, Hardkrome staggered straights, and the PR Bak with velocity stacks. Anyone have a map for this? I am getting HC pistons and cam kit with recall and plan to get a custom map then which I will post.
