Hey all,
every once in a while a remove stuff from my bike and clean them up. Regularly when cleaning my bike I notice moisture on the filler neck of the fuel tank. It became aparent that it wasn't sealing and/or draining the wash water correctly. I even started noticing whiting rust spots on the plate just inside the tank. So yesterdat I removed everything and gave it all a good clean and WD-40 wash I see a good amount of corrosion below the filler bezel. I applied a liberal amount of WD-40 and put everything back. Have any of you had problems like this when washing your bikes?
Also it seems I can't see any type of fuel filter on the Warrior. This makes me affraid that rust particles get into the fuel pump and injectors. Is this a valid fear factor?
Thanks, Xander
Thanks, Xander
