1 - 7 of 7 Posts
Just changed my gear oil and oil. Have a half quart of mobile 1 20w50 and half quart of valvoline synthetic limited skip 75w90 left over.
It's going to be awhile before i need to change oil again so pay it forward FREE to who ever needs to do this maintenance. Pick up only in San Diego. Should be enough for a gear change and cover the .5 of 4.5 oil change.
Flushed my brake fluid front and rear and I have half bottle of that as well.
Discussion Starter · #3 ·
Thank you hefty! I also dont mind helping out with the oil change since the procedure is unusual if needed lol.
Found some DOT 3 brake fluid and little less then half quart of redline MT90 as well
Do you still have this in located in poway
1 - 7 of 7 Posts
