Status
Not open for further replies.
1 - 20 of 35 Posts
Thread Title: Service Manuals by Model Year
Last Update: November 2nd 2012
This thread evolved to discuss:
  • Model Numbers (for Model Year)
  • Model Codes (for Purchasing Parts)
  • Service Manual Publication Numbers.
  • Service Manual Supplement Publication Numbers.
  • Parts Manual Publication Numbers.
Why you need the Model Number and the Model Code:
  • The Model Number is generic across each individual model year.
  • The Model Code indicates each individual Country or Region.
  • Motorcycles often eventually cross international borders.
  • Having the Model Number and Model Code can eliminate problems.
About Service and Parts Manuals:
When ordering a hard-copy Service Manual, be sure its the latest edition containing the 2002 service manual and the 2003 and 2006 supplements so that all model years are covered by a single manual-set. The 2003 and 2006 supplements cover prior ommissions and new changes. The same Service Manual applies to Original and Midnight Warriors. Parts Manuals differ.
About the Factory Build Model Year:
For USA/ISO format VIN's, the best way to verify the factory model year is to decipher the 17-character VIN. To avoid document errors, read the VIN from your motorcycle's frame neck, right side. The 10th character in the VIN is the model year: for example, a '2' indicates a 2002. This carries through 2009 so 10th character is a '9' for 2009 bikes. It appears the 2010 Canadian bikes use the same VIN sequence so for 2010 the 10th character should be the letter 'A' (but this is not verified).
Yamaha also built Warriors that were shipped to a few other countries using an abreviated 11-character Frame Serial Number and the model year character is not represented, and also built a small number of 'special build' Warriors that were shipped direct to buyers in various countries and their Frame Serial Number (VIN) stamped on the motorcycle neck follows an alternate abbreviated format (differences if any are unknown). In these cases it is possible to determine the Build Model Year by comparing the ECU/Engine Code to other Warrior motorcycles because Engine Numbers are assigned (thus serialized) at manufacture. See: http://www.rswarrior.com/forums/13-technical-discussion/170482-about-ecus.html for help.
About the Color Code:
To help you determine the factory color number, see the (usually white) sticker on top of the frame brace under your rider seat, and also note if the 'circle' is filled-in or not. Then see the separate chart (at the bottom of this section) dedicated to original color identification. Note there may be two different 'black' colors for the Midnight Warrior even though Colorrite showns just one color with two different sold-as names assigned by Yamaha. For Original and Midnight Warriors, the frame and engine are the same color but the engine paint may be high-temperature (unknown). The 'black' wheel color varies between Original and Midnight models, and some Midnight model wheels may have slightly different 'black' hues. Additional information organized by Model Year is available at: www dot colorrite dot com. (note two 'r' letters)
About Identifying Parts Correctly:
Use your known Model Year and your Model Code from below (example: 5PX1 or 2D81) to verify your parts are correct at time of order. The Yamaha / Star factory website and many dealer parts websites will indicate newer part number revisions but certain assumptions are often made based on country. For example, the Canadian factory and dealer websites will probably assume 5PX3 (etc) as shown below. So if your Canadian Warrior is now in another country and you visit a local dealer's parts website, you may (or may not) find different part numbers. Resulting problems are unknown.
About Model Numbers (by year) and associated Model Codes (by region or country):
Updated: November 2nd 2012
XV17PCP (2002) (P = 2002)
5PX1 for U49 (USA 49 states)
5PX2 for California USA
5PX3 for Canada and South Africa
XV17PCR (2003) (R = 2003)
5PX4 for U49
5PX5 for California
5PX6 for Canada and South Africa
5PX7 for U49
5PX8 for California
XV17PCS (2004) (S = 2004)
5PXA for U49
5PXB for California
5PXC unknown (possibly Aus/NZ/SA/Can)
XV17PCT (2005) (T = 2005)
5PXD for USA49
5PXE for California
5PXF unknown (possibly Aus/NZ/SA/Can)
XV17PCTB (2005 Midnight) (T = 2005) (B = Black)
2D81 for U49
2D82 for California
2D83 for Canada and South Africa
XV17PCV (2006) (V = 2006)
5PXG and 5PXG0 for U49
5PXH and 5PXH0 for California
5PXI unknown (letter 'I' possibly skipped as a character)
5PXJ unknown (possibly Aus/NZ/SA/Can)
XV17PCMV (2006 Midnight) (V = 2006) (M = Midnight)
2D84 for U49
2D85 for California
2D86 for Canada
XV17PCW (2007) (W = 2007)
5PXK and 5PXK0 for U49
5PXL and 5PXL0 for California
5PXM unknown (possibly Aus/NZ/SA/Can)
XV17PCMW (2007 Midnight) (W = 2007) (M = Midnight)
2D87 for U49
2D88 for California
2D89 for Canada
XV17PCX (2008) (X = 2008)
5PXN for U49
5PXO unknown (letter 'O' possibly skipped as a character)
5PXP for California
5PXQ unknown (letter 'Q' possibly skipped as a character)
5PXR unknown (possibly Aus/NZ/SA/Can)
XV17PCMX (2008 Midnight) (X = 2008) (M = Midnight)
2D8A for U49
2D8B for California
XV17PCY(2009) (Y = 2009)
5PXS for U49
5PXT for California
XV17PCMY (2009 Midnight) (Y = 2009) (M = Midnight)
2D8D for U49
2D8E for California
XV17PCZ-CA (2010) (Z = 2010) (CA = Canada)
5PXU (verify)
XV17PCMZ-CA (2010 Midnight) (Z = 2010) (M = Midnight) (CA = Canada)
2D8F (verify)
NOTE: 2011 New Zealand Warriors are believed to be 2009 USA49 models.
NOTE: 2012 South Africa models are believed to be 2009 USA49 models.
About Serivce and Parts Manuals: (specific publication numbers by model year):
The Short Answer:
Get Service Manual LIT-11616-RS-W1 (contains the 2002 manual plus the 2003 and 2006 supplements)
Get Parts Manual 2A5PX-100E2 for 2002 model year.
Get Parts Manual 2B5PX-100E1 for 2003-2009 model years and 2010 Canadian model.
Get Parts Manual 1D2D8-100E1 for 2005-2009 Midnight model years and 2010 Canadian Midnight model.
NOTE1: 2010 Canadian Midnight has gold-anodized forks that do not appear in the parts manual.
The Long Answer: (the following details are probably all solved by using the short answer)
2002 XV1700PCP* service manual is LIT-11616-15-37 (the original 2002 service manual by itself)
2002 XV1700PCP* parts manual 2A5PX-100E2
2003 XV1700PCR* service manual is LIT-11616-RS-WO (contains the 2002 manual and the 2003 supplement)
2003 XV1700PCR* supplement is LIT-11616-16-36
2003 XV1700PCR* parts manual 2B5PX-100E1
NOTE1: 2003 supplement covers prior ommissions and new changes.
2004 XV17PCS* service manual is LIT-11616-RS-WO (read Post #21 for electrical diagram notes, relay 9)
2004 XV17PCS* parts manual 2B5PX-100E1 (no 2004 parts manual known to have been issued)
NOTE2: 2004+ differences in rider peg mounts, handlebars and cables/hoses, seats and mount points, Start/FI Relay.
2005 XV17PCT* service manual is LIT-11616-RS-WO (read Post #21 for electrical diagram notes, relay 9)
2005 XV17PCT* parts manual 2B5PX-100E1
2005 XV17PCTB* midnight parts manual is 1D2D8-100E1 (also indicated on cover as 2D2D8-100E1)
2006 XV17PCV* service manual is LIT-11616-RS-W1 (contains the 2002 manual plus the 2003 and 2006 supplements)
2006 XV17PCV* supplement is LIT-11616-19-46 (2006 supplement)
2006 XV17PCV* parts manual is 2B5PX-100E1
2006 XV17PCVB* midnight parts manual is 1D2D8-100E1 (also indicated on cover as 2D2D8-100E1)
NOTE1: 2003 and 2006 supplements cover prior ommissions and new changes.
NOTE3: 2006+ differences in front brakes.
2007 XV17PCW* service manual is LIT-11616-RS-W1
2007 XV17PCW* parts manual is 2B5PX-100E1
2007 XV17PCWB* midnight parts manual is 1D2D8-100E1 (also indicated on cover as 2D2D8-100E1)
2008 XV17PCX* service manual is LIT-11616-RS-W1
2008 XV17PCX* parts manual is 2B5PX-100E1
2008 XV17PCXB* midnight parts manual is 1D2D8-100E1 (also indicated on cover as 2D2D8-100E1)
2009 XV17PCY* service manual is LIT-11616-RS-W1
2009 XV17PCY* parts manual 2B5PX-100E1
2009 XV17PCYB* midnight parts manual is 1D2D8-100E1 (also indicated on cover as 2D2D8-100E1)
2010 XV17PCY-CA* service manual is LIT-11616-RS-W1 (verify)
2010 XV17PCY-CA* parts manual is 2B5PX-100E1 (verify)
2010 XV17PCYB-CA* midnight parts manual is 1D2D8-100E1 (also indicated on cover as 2D2D8-100E1) (verify)
NOTE4: 2010 delivered to Canada only. Midnight has gold anodized forks.
2011 New Zealand Warriors (believed to be modified 2009 models, Model Code not known)
2011 XV17PCY* service manual is LIT-11616-RS-W1 (verify)
2011 XV17PCY* parts manual is 2B5PX-100E1 (verify)
2011 XV17PCYB* parts manual is 1D2D8-100E1 (also indicated on cover as 2D2D8-100E1) (verify)
NOTE4: if any have gold anodized forks they are 2010 Canada models.
Why should you consider your bike's 'built' model year and model number and also it's 'sold-as' model year?
  • Because in some countries the 'sold-as' model year is the year the vehicle is sold, not the year it was manufactured.
  • Because some factory shipments went to some countries late in the model year and were sold as the next model year.
  • The model years appear nearly identical except paint, but there were significant changes in 2003, 2004, and 2006.
  • For more information, see the 'Model Year Difference' thread.
Where to Find Manuals:
Manuals - Star (USA) website: YAMAHA MANUAL STORE
Manuals - 2002 Service, 2003 and 2006 Supplements: Road Star Warrior Documents
Manuals - 2002 and 2003-2009 Original Warrior Parts: http://www.rswarriordocs.com/index.html
Manuals - 2005-2009 Midnight Warrior Parts: http://www.rswarriordocs.com/index.html
Manuals - 2002 Service: http://www.blackcaps.nl/forumfotos/warrior_service.pdf
Manuals - Various Yamaha: Paul MILNER's Homepage (manuals no longer hosted)
Manuals - Owners: Star Parts & Service Home
Factory Original Colors by Model Code:
Updated: May 24th 2012 (note there are still several missing color codes)
2002 XV1700PCP 5PX1 (color A B C) USA49.
2002 XV1700PCPC 5PX2 (color A B C) California.
2002 XV1700PCP 5PX3 (color A B C) Canada and South Africa.
2002 Color A = 'Dark Gray Metallic A' (DNMA / 0821) which sold as 'Titanium'.
2002 Color B = 'Dark Violet Metallic A' (DVMA / 0778) which sold as 'Indigo'.
2002 Color C = 'Vivid Red Cocktail 7' (VRC7 / 0580) which sold as 'Imperial Red'.
2003 XV1700PCR 5PX4 (color A B) USA49.
2003 XV1700PCRC 5PX5 (color A B) California.
2003 XV1700PCR 5PX6 (said to be special builds).
2003 XV1700PCR 5PX7 (color C) USA49.
2003 XV1700PCRC 5PX8 (color C) California.
2003 Color A = 'Dark Gray Metallic A' (DNMA / 0821) which sold as 'Titanium'.
2003 Color B = 'Silver 3' (S3 / 5175) which sold as 'Liquid Silver'.
2003 Color C = 'Yamaha Black' (YB / 0033) which sold as 'Onyx with Indigo Flames'.
-- The Factory Nomenclature Changed --
2004 XV17PCS 5PXA USA49
2004 XV17PCSC 5PXB California
2004 Color A = 'Dark Bluish Gray Metallic 8' (DBNM8 / 0919) sold as 'Cerulean Silver with Flames'.
2004 Color B = 'Dark Violet Metallic A' (DVMA / 0778) sold as 'Indigo with Pinstripes'.
2004 NOTE: A and B could be reversed?
2005 XV17PCT-F 5PXC USA49 'Dark Violet Metallic A' (DVMA / 0778) sold as 'Indigo with Pinstripes' (not manuafactured?).
2005 XV17PCT-F 5PXD USA49 'Very Dark Red Metallic 2' (VDRM2 / 0957) sold as 'Black Cherry Flames'.
2005 XV17PCTC-F 5PXE California 'Very Dark Red Metallic 2 (VDRM2 / 0957) sold as 'Black Cherry Flames'.
2005 XV17PCTB 2D81 USA49 'Yamaha Black' (YB / 0033) sold as 'Onyx' and 'Midnight'.
2005 XV17PCTCB 2D82 California 'Yamaha Black' (YB / 0033) sold as 'Onyx' and 'Midnight'.
2005 XV17PCTB 2D83 Canada and South Africa 'Yamaha Black' (YB / 0033) sold as 'Onyx' and 'Midnight'.
2006 XV17PCV 5PXG USA49 'Deep Red Metallic K' (DRMK / 0918) sold as Candy Apple Red with Stripes'.
2006 XV17PCV-F 5PXG0 USA49 'Deep Purplish Blue Metallic U' (DPBMU / 996) sold as Cobalt Flames'.
2006 XV17PCVC 5PXH California 'Deep Red Metallic K' (DRMK / 0918) sold as Candy Apple Red with Stripes'.
2006 XV17PCVC-F 5PXH0 California 'Deep Purplish Blue Metallic U' (DPBMU / 996) sold as Cobalt Flames'.
2006 XV17PCMV 2D84 USA49 'Yamaha Black' (YB / 0033) sold as 'Onyx' and 'Midnight'.
2006 XV17PCMVC 2D85 California 'Yamaha Black' (YB / 0033) sold as 'Onyx' and 'Midnight'.
2006 XV17PCMV 2D86 Canada 'Yamaha Black' (YB / 0033) sold as 'Onyx' and 'Midnight'.
2007 XV17PCW 5PXK USA49 'Dark Bluish Gray Metallic 8' (DBNM8 / 0919) sold as 'Charcoal Silver with Stripes'.
2007 XV17PCW-F 5PXK0 USA49 'Dark Grayish Blue Metallic E' (DNBME / 0866) sold as 'Sapphire Blue with Flames'.
2007 XV17PCWC 5PXL California 'Dark Bluish Gray Metallic 8' (DBNM8 / 0919) sold as 'Charcoal Silver with Stripes'.
2007 XV17PCWC-F 5PXL0 California 'Dark Grayish Blue Metallic E' (DNBME / 0866) sold as 'Sapphire Blue with Flames'.
2007 XV17PCMW 2D87 USA49 'Yamaha Black' (YB / 0033) sold as 'Raven' and 'Midnight'.
2007 XV17PCMWC 2D88 California 'Yamaha Black' (YB / 0033) sold as 'Raven' and 'Midnight'.
2007 XV17PCMW 2D89 Canada 'Yamaha Black' (YB / 0033) sold as 'Onyx' and 'Midnight'.
2008 XV17PCXR 5PXN USA49 'Deep Red Metallic K' (DRMK / 0918) sold as 'Candy Red with Black Sides'.
2008 XV17PCXCR 5PXP California 'Deep Red Metallic K' (DRMK / 0918) sold as 'Candy Red with Black Sides'.
2008 XV17PCMX 2D8A USA49 'Yamaha Black' (YB / 0033) sold as 'Raven' and 'Midnight'.
2008 XV17PCMXC 2D8B California 'Yamaha Black' (YB / 0033) sold as 'Raven' and 'Midnight'.
2009 XV17PCYS 5PXS USA49 'Silver #3' (S3 / 0791) sold as 'Liquid Silver'.
2009 XV17PCYCS 5PXT California 'Silver #3' (S3 / 0791) sold as 'Liquid Silver'.
2009 XV17PCMY 2D8D USA49 'Yamaha Black' (YB / 0033) sold as 'Onyx' and 'Midnight'.
2009 XV17PCMYC 2D8E California 'Yamaha Black' (YB / 0033) sold as 'Onyx' and 'Midnight'.
2010 XV17PCZ-CA 5PXU? Canada (believed 'Deep Red Metallic K' (DRMK / 0918) sold as ?.
2010 XV17PCMZ-CA 2D8F? Canada (believed 'Yamaha Black' (YB / 0033) sold as 'Midnight'.
Universal Note: Flame in paint is believed to be decals but not positive only assumed.
[upated February 24th 2009 by ArizonaWarrior with help from Desertwndrr for 2006 Supplement data]
[updated July 19th 2010 by ArizonaWarrior to repair broken link and add 2009 parts manual info]
[updated January 4th 2011 by ArizonaWarrior to re-format for the new forum parameters, and update]
[updated May 3rd 2011 by ArizonaWarrior to update known 'selling model numbers' (pending a seconf verification]
[updated May 3rd 2011 by ArizonaWarrior to correct and expand sections covering how to identify model year, and factory model number]
[updated May 17th 2011 by ArizonaWarrior to include known parts manuals previously omitted]
[updated June 30th 2011 by ArizonaWarrior to refresh the link to the Model Year Differences post]
[updated October 24th 2011 by ArizonaWarrior to simplify choice of manual and clarify other details]
[updated February 18th 2012 by ArizonaWarrior to re-organize, clarify, and add new details]
[updated May 24th 2012 by ArizonaWarrior to correct some code numbers, and add paint color identifiers section]
[updated June 15th 2012 by ArizonaWarrior to correct and clarify two codes]
[updated November 2nd 2012 by ArizonaWarrior to correct missing alpha-characters in model codes]
hiya - uk bike 2004 still has one piece seat and pegs for passenger not lowered - not an import bike brought into uk by yamaha - now wondering if it's actually a 2003 model - which makes accessory buying a different matter - regards tomba
Excellent point, I've added that to the post above. Your keen observation is very much appreciated.
If your guess is correct then I'm wondering if your 2004 bike is model #XV1700PCR* (where * means there's more characters that might change the color or some other minor feature of the basic model).
Re: Service Manuals by Model Year - (Hey Tom How R Ya?!)
Data updated to include 2006 supplement and 2009 service manual (same as previous). It seems like:
For2002 model year you need just the service manual (supplement helps).
For 2003-2005 you need the 2002 service manual and the 2003 supplement.
For 2006-2009 you need the 2002 service manual and the 2003 supplement and the 2006 supplement (worst case its overkill).
Does this seem right?
As I read these the P/N LIT-11616-RS-W1 merely means to me that it is a bundle of the service manual and both supplements because when openedthe front pagestill references the service manual part number.
I would also assume that because it has both the 2003 AND the 2006 supplements that there would be information contained in the 2003 supplement that supercedes the service manual but is relevant and therefore not needed to be rewritten into the 2006 supplement. So for 2006-2009 model years you would still need both supplements.
I have not checked all the information contained within to verify any of this.
Hi Tom. The Warrior was only officially brought into the UK in 2002 and 2003. All other years are imports.
How un fair is that.
Of course Tom's 2004 model UK bike is actually a 2003 model USA bike so it looks like maybe there were a few shipped as UK domestic in 2004. Or the dealers sold them as 2004 who knows. But one way or another the 2003 model bike was sold as a 2004 in the UK. They even have the 2003 model number on them, which Tom mentions earlier above.
The result is very positive.Tom and I have the same bike.2003 Titanium metallic (gunmetal) - the fastest Warrior ever built!!
Absolutely correct
[*]titanium is very smooth...but mine does have the faster exhaust..
yup last time i looked yours had fallen off.. now if you need one..and i understand that desire..really i do Mike..i have a spare kindly donated to the BBB's club by ianR....of coursereplacing the lack of chrome with the L&Mdoes help [lol]....but when you arrive in London it'll feel nearly like home
The only thing that's got me puzzled is why did 'they' nick my second horn? and as it happens today, i poked my beak up that gap and could see no wires or connector for it either!!? wtf..
Saw pics of MwUk [adams] new bike yesterday - very clean and still has the bazooka, joy![oh just because adams taking it off anytime soon doesn't count!] - his is an 03 on an 02 plate, has 2 horns but doesn't look titanium a bit paler perhaps [nearly silver] is that a standard colour? bone has looked at it and has 'import' as it's pedigree....Az you still smiling?...i hope!
Discussion Starter #11
Hey Tom, I had to go back to model year differences to be sure, I'm getting old.
'03 colors were Liquid Silver Metallic, Titanium Metallic, and Onyx with Indigo flames. There wasn't a midnight version yet. Since those are the only colors showing in parts for replacement bits I'm guessng they are the only colors made by the factory for all countries, but who knows.
Hey mike..nearly missed this coming back [for some reason i don't get the notifications in my e-mail anymore?] hmm..anyways..sounds like he's got the liquid silver metallic..
oops...how ami going to break the bad news!!?...'ukk hmm man it's bad news'..'yea better be seated'....'it ain't titanium!' ...that should do it
Don't think i didn't notice the lack of arguement on that other matter lol...but no arguement about ageism here [i'm so much older than you!]
Discussion Starter #16
The link in the original post (above) has been updated. The new link also leads to a hard-copy purchase option.
Note: my most recent info is that factory manuals for all model years ship with the 2002 manual as the basis of the document. Separate supplements are added for newer models as needed. At this writing there were two supplements (see list above). Therefore, as long as this remains true, if the price is the same you might consider getting the newest model year maual then simply ignore any supplement that doesn't apply to your model year. Hopefully there is some way to verify before buying.
[/list]
Also see the 'Popular Mods' post in the Technical forum, and look under 'Manuals' for the e-copy option.
boostin2g said:
I've seen links to pdf files. I want a hard copy. Does anyone have a go to site to buy motorcycle publications ?
I ordered mine from a dealer several years ago. It's cheaply made, the pages come out too easily. Crappy binding, but it still works, as much as a book "works".
1 - 20 of 35 Posts
Status
