1 - 20 of 25 Posts
I am kind of relieved that I didnt go down this weekend but after a long hard ride on sunday I was on my way home and some guy on a RC-51 wanted to play. So on the back roads we went fast and hit a lot of hard curves that I have ridden many times. After a long stretch I was blown away by the RC-51 top speed and I wanted the lead back, and very foolishly blasted past him in a tight right turn and wham, the feeler hit and broke off, then my mini boards hit, then the foot peg bracket started grinding, then my exhaust pipes hit the ground. Now I have huge scrapes all along the bottom of my big shots, from just behind the foot peg bracket and about 10 inches back. The bike didnt even wobble, it just hung in there. I am a little disapointed that they hit b/c I was told that they would not. Well this might be an extreme example but I learned that the pipes do hit And I also learned never to do that again.
Ride Safe.
John
Wow, that was close. Look at the bright side though, you now have confirmed that a ton of other crap will hit before the BigShots. In the future, you'll know when to back off. What really sucks is a pipe that hits before anything else in tight right sweepers, at least that is not the case....
BTW, I've always wondered which would scrape first under the same situation, the Propipe or the Big Shots....
jrd, is your bike lowered? I am hesitant to lower my bike, I dont like dragging my money on the ground (well ok I like it, but I cant afford it.)
Tim
Buy John a Propipe and he'll let you know... [/emoticons/emotion-2.gif]
jrd, you did the ride thing... just don't do it again !!. If you are a canyon crazy like me, you can raise the bike a bit !!!
Discussion Starter #13
Timmymorg, No my bike is the stock height. The only thing that I have done to the factory set up was tighten the adjustments on the forks by one and a half "clicks" or "adjustment marks". I am 5' 10" and 170 lbs. The bike barley squats when I am sitting on it.
Rule of thum there is now way to beat a rc51 my roomate has one and I ride that also the thing is a animal. Speed is not a problem infact he can be up to 150 before I hit 3rd gear and dip into a turn at 3 times the speed I can. The only problem is that after a 1/2 hour you are tired and your arms hurt on the rc51. So I will out last him any day. Infact he is thinking of selling it after riding my bike and getting a roadstar.
Look athe the bright side you only need to replace one heat shield. and a bunch of other stuff dragged first. If you kept on going I'm sure you might of hit that huge air box. Could of been worse you could of had rhinharts.
I'm with the programmer. I ride with an RC51 fairly regularly and if you can keep up to one, the guy riding it has his dick in his purse. But hats off to ya it sounds like you really know how to wring out the warrior.
1 - 20 of 25 Posts
