1 - 3 of 3 Posts
Ihave an 05 midnight with shogun short slashers, and a dyno jet pc I need to change tne plugs and what the best bang for my buck any suggestions
Everyone has an opinion so here is mine. If you intend to stay with a regular type plug, I like denso better than ngk.
I agree with Jabo that there's a lot of options. There's also a lot of conversation on this topic from a lot of different aspects. Here's the spark plug links from the Popular Mods post:
Spark Plugs - OEM: NGK DPR7EA-9 - or - Denso X22EPR-U9 from factory (gap 0.8mm to 0.9mm)
Spark Plugs - Preferred: 4 each NGK Iridium DPR7EIX-9 (7803) 0.032" ~ 0.035" (0.8mm to 0.9mm)
Spark Plugs - NGK Part# Key: http://www.ngksparkplugs.com/docs/tech/partnumberkey.pdf
Spark Plugs - E3 (not yet tested): http://rswarrior.com/forums/t/120319.aspx
Spark Plug Wires - High Performance: http://rswarrior.com/forums/t/26756.aspx
Spark Plug Condition Chart: http://hawkworks.net/sparkplug-chart/
Spark Plug Condition Chart: http://www.ngksparkplugs.com/techinfo/spark_plugs/faq/faqread2.asp
Spark Plugs - Changing: http://rswarrior.com/forums/t/26477.aspx
Spark Plug Condition Info: http://www.strappe.com/plugs.html
Spark Plug Reading - Racing: http://www.usaimports.co.uk/Mopar_Tech_Pages/Spark_Plug_Reading.htm
Plugs last a long time these days. If you learn to "read" your plugs you'll be able to make corrections to problems so you don't simply foul another set of plugs.
1 - 3 of 3 Posts
