If you can translate the warrioir injector flow rate to lbs per hour (PPH) a figure the auto industry uses there is probably an injector that will interchange with the Warrior. Fords will fit GM etc. & they are available inmany PPH ratings. I doubt that Yamaha designed, developed & manufactured an injector specifically for the Warrior.IMHO theyuse a standard production injector. I never bothered to investigate an injectorinterchange simply due to the fact that the stock injectors are adequate for my application.
In addition to thePPH rating you willneed the dimensions of the Warior injector. Body diameter is not critical, OAL & O ring diameters are.
I agree that the price of the speed star injectors is out of this world. I recently purchased a new set of 8 flow matched Bosch 111 injectors for a 350 Chevy motor for 189.00 from an injector specialty shop.
