Tausch ... my .02 follows ....after reviewing your gallery inventory, assuming it's up-todate,noting that you're running the stock frt & rear turn signals less the license plate light and have the OEM decomp and cam covers simplifies the trouble shooting process.
Some of the aforementioned mods mentionedby
Marco Polo,can havechronic problems that contribute to what might appear to be a bad battery but isn't.
Becausethe weak battery has been preexisting since day one, i would agree with Marcoand not replace itat this time.I would check all relevant connections and devices that would contribute to this problem as stated by
Dice.
A typical symptom of the battery going bad is the trip odometer resetting to zero![/list]
My tools of choice for this challengewould be a Digital volt ohm meter ($10.00-$15.00) and Battery Tender Jr ($30.00)) at a minimum.
Charge the battery completelyoff the bike and when done check the output voltage.Awell charged AGM battery will yield > 12.7vdc ... my OEM GS battery (> 60 months old)puts out 12.84vdc when fully charged with no other connections today!
Alternatively, take the battery to a reliable shop and have it load tested after being fully charged.
While the battery is off the bike you'll want to do your due diligence in making a proper inspection of allthe high current carrying cables and terminating connectors to the Starter Relay (Item7
http://www.fileden.com/files/2008/1/1/1673654/Warrior/Warrior%20Schematic.pdf)as this could cause your problem. Remove and inspectspade connectors.
Thoroughly inspect the starter motor connector under the rubber boot for tightness and validate the mechanical crimped connection as well as the battery positive and negative cables.[/list]
midnight_run - Faulty Starter Relay symptoms and fix w/ part no. http://rswarrior.com/forums/p/122342/979530.aspx#979530
Churchkey - Bike Dies when i pull the battery cable.
http://rswarrior.com/forums/p/118726/957003.aspx#957003
3rd paragraph:
Quick visual check. stand in front of the bike with the engine running & look at the head light. Reach over & shut the bike off with the kill switch while watching the head light. If the head light gets dimmer when the engine shuts off the charging system is functuning. If it gets slightly brighter the charging system is not functuning. [/list][/list]
