1 - 11 of 11 Posts
I'm not sure what the Dyno showed before with just the V&H Pro Pipe. With the new Mods, I had it Dyno mapped. I'm getting 85.5 HP and 101.4 on the torque side.
The bike has an awesome SNAP to the throttle. Do these #'s look about right?
Chris
Sounds just about right with those mods. You think it's snappy now, drop some HC pistons in there and hang on!!
That was the next question. WHATS NEXT? Where do I get it?
Hey your from the AK!! I used to live in ANC. Worked for GCI. I have a buddy who lives out there by you.
That brings me to a good question....I'm jealous of all the 02 folks that got HC pistons installed for free (not that I would want that recall mess). How much of a job would it be to install HC pistons myself? I'm very mechanically savvy....Rebuilt small blocks growing up. but never opened up a bike engine. I've searched for this with no luck, Should I post a new topic?
Your next mod has to be open the air system.
1)K&N replacement filters
2)PR,Curchkey or Barons BAK.
3)Any other air system replacement.
Go to dyno again.
Next mods:
HC pistons,cams,valve job.
Sounds about right to me. Maybe a touch higher that some with the same mods.
Condrons, your question has been done by several members. With a shop manual a mechanically savy tech could do this very easily.
Get a better BAK - get more power. Any BAK with vstack will beat your numbers. With a PR BAK for example I would expect some 89-90 rwhps with the pro-pipe.
The Barons BAK is purely for looks - it does little for performance.
Funny I must have a strong bike becuz I just have the V&H Pro pipe and I had a dyno run with 88 rwhp. I am picking up my PRBAK tomorrow, can't wait to see how it runs with that.
Frankenstein told ya right about the Baron's Stealth BAK. I tossed mine and went with ChurchKey's V-BAK with my own "homemade version" of the Coil relocation plate with the Dyna Coils.
The main reason I purchased the Baron's was because of the clean-up on the front of bike. After being a member on this forum for awhile I realized that I had just wasted my money and time.
So I had to make a plate that would allow me to use the Dyna Coils (they are fatter), and allow room for the V-BAK and the filters. Had to off-set location of coils in order to achieve this goal due to the lack of room under tank.
Baron's just mounts their supplied K&N's directly onto the throttle bodies. Doesn't do anything much that I could tell. However,..the V-BAK woke it up bigtime.
Insert Image:
74.5 KB
These are K&N RU-2550's that I used for awhile because of space, and they were big enough. They did the job. I always wanted to re-work and put on the filters that were intended for the kit. This past Saturday I replaced the RU-2550's with the K&N RC-1290's that are recommended for the V-BAK. Had to move everything around alot and re-work alot of stuff to make room, but it worked out great.
I forgot to take a picture of my completed project. Here's a picture of the K&N RC-1290's from another member on the forum versus the RU-2550's that I had been using!
Insert Image:
43.02 KB
Insert Image:
34.86 KB
Insert Image:
30.87 KB
Baron's Stealth BAK
1 - 11 of 11 Posts
