1 - 16 of 16 Posts
So I have searched over and over here and didn't see if Yamaha changed the final lower ring final torque.
Some info I have found on most other Yamaha bikes with tapered roller bearings is that the final lower ring nut is or has been revised and changed to 13 ft lbs. Our manual shows 2.9 ft lbs. This is so low that it can be done by hand just the 2" nut spanner and your hand without trying hard.
Has this been done for the warrior aswell? If not why?
These other Yamaha motorcycles are in the same weight and higher with the same style bearings.
2.9 ft lb seems pretty low to me and obviously Yamaha since it raised spec.
I know we've ran with the final torque most without issue but we have ran with wrong torque settings on other parts of the bike with out issue but it doesn't make it right.
Did Yamaha forget to update our final torque of the steering head lower ring nut and just kept it the same.
I did do a small test yesterday when I torqued my ring nut down and to stayed 2.9 ft lb and the steering felt loose still. I then started the steps over and gradually raised the torque checked and it began to feel normal like my other bikes.
I stopped at 11 ft lbs and it feels good and tight now. But of coarse not where it won't turn but to where it slightly falls to the side when turned some.
I have some other service manuals and am looking for more.
In the pics show their initial and final steering head lower ring nut torque.
I believe the warrior 2.9 ft lbs should be raised to maybe 13 ft lbs like other models like Yamaha changed and or raised.
Roadliner/Stratoliner/ Raider
Road star 1700's 04'-07' (I've only seen this written and mentioned to members in forums so far with complaints of the 2.9ft lb started in manuals)
Road Star 1700's 08" up
Royal Star Ventures
1st gen VMax 98-07 (I've also only seen this written and mentioned to members in forums so far with complaints of the 2.9ft lb started in manuals)
2nd gen VMax 08" up
Star Venture/Eluder
Other models that use the tapered roller bearings style mention the same 13 ft lb setting but I can't find manuals.
It seems that all that use Tapered roller bearings have a final torque of 13 ft lbs to the steering head bearing lower ring nut.
There are many other models which use angular ball bearing style bearings which seem to be the lighter bikes even up do date so I won't bring those up into this torque discussion as there not using tapered roller bearings like those other bikes mentioned but those are from 10- 13 (about 10 other models I have manuals for)
I believe you are right. After a couple attempts a few years ago that loosened, I got two wrenches to hold the bottom nut and twist the top nut and kept stepping up tightness until my front tire stayed put on the kickstand unless bumped. It has not loosened. I do not know the exact torque value. And once it was right I did not bother to investigate.
I know allot of people adjust by feel and I used to on other applications but this time I checked the feel and torque reading.
What brought this to my attention also was that I was reading about another steering head bearing issue of being loose and it was a Road star. I read more and it turned out Yamaha had the wrong final value.
2.9 lbs isn't tight and seems to be too loose.
I also noticed when I did mine I tried set it to 2.9 I kept turning forever and realized while the bike wheel is off the ground the steering stem assembly would slide down a bit when I loosened the lower ring nut per directed to re torque to its final torque. I eventually had to torque back to 37 then stock a block under the tire to hold everything in place then loosen the ring nut and torque to 2.9 ft lbs.
After feeling it this way I thought higher torque would be needed to stiffen the feel and pull the steering stem back tightly again. It didn't seem like the 2.9ft lb would pull the stem up and tight enough.
I'm going to keep looking to see what more i can find out about this torque but I would think from what I've already gathered is that Yamaha wants it to be 13 ft lbs as in the other models.
Not sure of the torque values but torquing down your steering head is a two step process. At first you torque it down to a high value which sets the bearings. Once this is done you back off the nut and then torque it down to the lower value which is the value it should be set to.
I'm certain Rudy knows, because, well, its Rudy, so not just from the first OP sentences, that said I gotta say thanks for posting it so others into the future realize. This highlights for me that when big beasts like you and Rudy and so many others post, its maybe smart to come right out and say these inferred things for those who follow having the same troubles.
I have a question, is this process/torquing the same when you install 6°-7° triple trees, I plan on doing mine this winter???
I just found info from Gilly on his torque with his morons trees.
Screenshot pics posted
It depends on the manufacturer, I've seen some single torque over the decades. Although I have not seen a huge number of different designs so I am interested in more info. Excellent question.
Right, If they didn't come with instructions/ torque settings I would search/ call the manufacture up. Otherwise I guess the next best thing is to follow our initial 37 ft lbs and final torque setting to a feel/ bump test.
I believe Gilly that followed the 37 ft lbs then final 13 ft lbs or the flop test with his morons.
Edit-
I just found info from Gilly on torque with his morons trees.
Also found a bit of info he mentions a bit of the change in final torque aswell with the Road star.
yes it is. when I put my 6 degree trees on I used the instructions that came with morton 7 degree trees provided graciously by Gilly as my tree maker did not provide instructions
Discussion Starter #11
So I've found a bit more info regarding other Yamaha models that use the tapered roller bearings and I've added to my first post.
It seems that only the heavier cruises use these style bearings.
I've also asked these other Yamaha model bikes groups and have gotten a couple owners stating that when they set to those lower final torque they had developed wobble and tightened further.
Discussion Starter #13
Rudy I had this problem as well when I rebuilt my forks and decided to replace the bearings in the neck since they were bone dry. I had a friend help me with the forks and he advised me that 2.9 must have been a typo cause there ain't no way that was correct. We probably thought it should have been 12.9 so we did like you and did 13. Been good ever since.
Discussion Starter #15
It just seems way you low especially for supporting a heavy bike.
I wonder how many have tightened and kept theirs to the 2.9.
I have seen a couple guys complain about wobble so I'm guessing they have loose bearings aswell.
I think when you are ready the title of this thread can be amended and the thread made sticky at top of this forum for ease in finding it.
I will write it in my service manual for certain but the old note sheet posted is hard to update being also hosted where it is.
Maybe we all need to get together and build a new sheet. Call it Notes from All Our Service Manuals. I can put it into Documentation when it's ready.
You could start the thread if you want.
What do you think about adding this torque info to the 'Notes from my Service Manual ' section
https://www.rswarrior.com/forums/2017412-post28.html
Or do you think it's too soon?
Pg. 2-25, 4-76, 3-51.
1 - 16 of 16 Posts
