1 - 8 of 8 Posts
Hello to ya'll.Im a 2 time newby.Just got a new Midnight Warrior and just joined this group. First question is about grip removal.I'm going to put Iso-Grips on and want to save the OEM's.How do you get the left grip off without cutting it? Second question is about the crickets I'm hearing from my BigShots that I just installed.Did that and AIS removal/block,went for a ride + when I shut her off in the garage I listened to some cricket like noise for about eight minutes as the pipes cooled.Any body care to chime in?It's too late to call an exterminator.
On the left grip:
Grasp the chrome end piece, twist and pull. It's just a friction fit to the bar. Then work a screwdriver under the rubber grip to loosen the glue. Compressed air will just about blow the thing right off. Or inject some soapy water in there and twist it off.
Welcome...on the grip, you can also use wd-40. Stick the little straw up under the grip as far as you can, and spray. Mine popped right off.
1 - 8 of 8 Posts
