All,
I needed to cancel all subscriptions to the site. They werent working anyway, so you should miss much.
The new set up will (hopefully) let you subscribe to a TOPIC, and send you an email when someone replies to it. There will be another minor upgrade to the Forum soon that will hopefuly fix the subscription problem once and for all.
To use this, when you are creating a new topic there should be a check box below "Include your profil signature" Check it if you want to be notified via email.
Also, It is only enabled for topics created in the Warrior Forums (Technical and General) as well as this forum.
The subscription feature can effect speed greately, so if the forum gets to slow because of subscriptions I will need to disable them totally.
CarKnee
CarKnee
