1 - 10 of 10 Posts
Looking to have a big fatty put on the back of my warrior this off season. Wanted to have the swingarm modified to accept the 250 tire and also wanted the rear wheel widened as well. I want to keep the stock wheels and just have them powdercoated black just like the midnight warrior's wheels are. I have also read here on the forum about "Crown" as being the man that may be able to help this to be a reality. Does anyone know how to get in touch with him? If you do, please let me know, or if you have any other shops that do reputable work drop a line as well. Thanks Woodrow Oh yeah, need to know more about the hidden rear caliper mod as well.
Some people would've just told you to use the "search" option..................I however am not that guy.
I used Crown when I did my 260 kit and caliper mod. He was very attentive to detail, answered all my questions, and did an excellent job. I would definitely use him again if need be. Heck, I imagine that he may even have parts on hand ready toswap out at this point?
[email protected] is his email address. You can also try to PM him from the site here.
And to tease you a little................pics!
260 is the widest tire that sits in the stock fender. Crown does widen the wheel and swingarm. Good thing about Crown is you have an option on wheel width. You can go 8.5" which is what the other venders sale or you can go 9" which is a better width for the 260.
This is a cycle image arm with an 8.5 inch RC wheel & a 260mm tire
By claypool782, shot with DSC-T300 at 2009-04-23
This will help you with your searches: http://rswarrior.com/forums/t/115929.aspx
Tires - Rear - OEM and Custom Sizes: http://rswarrior.com/forums/t/16550.aspx
Tires - Rear - Width - Custom: http://rswarrior.com/forums/t/26620.aspx
Tires - Rear - Dimensions and Rims: http://rswarrior.com/forums/t/26626.aspx
Tires - Rear - Fat Tire Group Buy: http://rswarrior.com/forums/t/2227.aspx
Swing Arm Nut Size: 27mm (1-1/16") (6-point shallow socket)
Swing Arm and Suspension - Removal: http://rswarrior.com/forums/t/49002.aspx
Swing Arm and Suspension - 190 mm: http://rswarrior.com/forums/t/24539.aspx
Swing Arm and Suspension - 200 mm: all stock (see also 'tires')
Swing Arm and Suspension - 210 mm: all stock very tight fit - do a search for more info
Swing Arm and Suspension - 240 mm: http://rswarrior.com/forums/t/28163.aspx
Swing Arm and Suspension - 240 mm: http://rswarrior.com/forums/t/29030.aspx
Swing Arm and Suspension - 250 mm: http://rswarrior.com/forums/t/27748.aspx
Swing Arm and Suspension - 260 mm: http://rswarrior.com/forums/t/29181.aspx
Swing Arm and Suspension - 260 mm: http://rswarrior.com/forums/t/109486.aspx
Swing Arm and Suspension - 260 mm: http://rswarrior.com/forums/t/111212.aspx
Swing Arm and Suspension - 280 mm: http://rswarrior.com/forums/t/29136.aspx
Swing Arm and Suspension - 280 mm: http://rswarrior.com/forums/t/28417.aspx
Swing Arm and Suspension - 280 mm: http://rswarrior.com/forums/t/28276.aspx
Swing Arm and Suspension - 280/300mm: http://www.bluesteelcustoms.com/home.html
Swing Arm and Suspension - 300 mm: http://rswarrior.com/forums/t/28045.aspx
Swing Arm and Suspension - 300 mm: http://rswarrior.com/forums/t/28123.aspx
Swing Arm and Suspension - 300 mm: http://rswarrior.com/photos/TTBONE/default.aspx
Swing Arm and Suspension - 360 mm: http://rswarrior.com/forums/t/2969.aspx
Swing Arm and Suspension - 360 mm: http://rswarrior.com/forums/t/13398.aspx
Swing Arm and Suspension - Group Buy: http://rswarrior.com/forums/t/2227.aspx
Swing Arm and Suspension - Comparison Pic: http://rswarrior.com/forums/t/24539.aspx
Swing Arm and Suspension - Single Sided: http://rswarrior.com/photos/ohiomike/default.aspx
Swing Arm and Suspension - Single Sided: http://rswarrior.com/forums/t/120084.aspx
Swing Arm and Suspension - Single Sided: http://rswarrior.com/forums/t/131084.aspx
Hi
Nice looking bike, can you advise what type and make is the exhaust?
Kylenv also does the wide tire kits. My old 260 kit was from him and I was more than pleased with it. If you go on the forum section and then scroll down to the site vendors you will find both crown and Kyle. You can usually run a 260 tire with the stock fender however you may need to do a little shimming. If however you run an Avon 250 tire which in fact is a bit wider than the meteler 260 that a lot of people also use you may have a problem with the stock fender. Some people have had problems and have had to widen the fender or go to a custom fender.
Hey, see that this post was quite awhile ago. Do you still have this sick ride? I was looking to customize my wheels on my 02 Warrior. I was wondering if you could help me out as far as pointing my in the right direction, which website you'd order from, what size the front wheel is, ect. Thanks! Hope you're still riding the sexy beast!
1 - 10 of 10 Posts
