1 - 5 of 5 Posts
How do you correctly remove the select and reset buttons from the tach housing. Trying to put on Cadfather polished tach and stuck at this point. Need some help. Do want to damage anythig.
Thx.
You'll need to lift up the chrome rings with a very small screwdriver (very gently, to avoid damage). Once they're off you can squeeze the rubber a bit to push them down, through the hole.
>> Take your time for this, it all damages quite easily! <<
1 - 5 of 5 Posts
