1 - 8 of 8 Posts
Hey Guys,
I'm waiting on parts to arrive to finish a bunch of mods that I have in the works and while I have the bike stripped down I'm working on cleaning all the little nooks and crannies that I've been neglecting over the years. After installing the Churchkey VBAK last spring, I now have an unobstructed view of the throttle bodies and want to get in there and clean off all the gunk that's accumulated on the exterior of them. I'm wondering if its safe and advisable to use some kind of engine/carb cleaner on the exterior to blow off all the gunk without damaging the electrical, vacuum hoses, fuel lines etc... then getting in there with some soapy water, a tooth brush and some elbow grease to get it properly cleaned. Once I get it clean it will be just maintaining it but right now its pretty nasty.
Daniel
I think you'll have good luck just with some simple green, or purple power and a small brush. That's what I did. I've never been a fan of those harsh engine cleaners from the spray can.
I'm with him. Simple Green is safe for your frame paint and wiring, but will clean most engine dirt and gunk.
I's only use carb cleaner on a throttle body when removed from the bike.
Don't like simple green it will soften some types of paint.
Suggest mineral spirits. Have a syphon blow gun? If so blast it clean if no then brush it on & let it soak for a few then blow it off.
While your in there put a wrench on the manifold to head fasteners they tend to work loose.
Purple power is corrosive and water based, even simple green is still water based. I dont recomend you use either to clean something that may allow leakage of something that's not pil based down into your cylinder...even wd40 would be better than simple green. Get some seafoam and a plastic bristle brush, mineral spirits will work fine also but try to avoid pouring it onto the valves.... better to use a toothbrush and a small jar of cleaner and a clean cloth.
Awesome, thank you. It never occurred to me to use compressed air! I'll rock the mineral spirits followed by air to get it properly clean then compressed air to maintain it later on.
Isn't Seafoam an engine treatment? Do they also have something to spread/spray on the exterior or are they all the same product?
I want suggesting putting either of those cleaners IN the throttle bodies, but on the exterior you should be fine as long as you dont spray it around like crazy. And yes purple power should be diluted.
But the mineral spirits idea works too. Even WD40 or some other light oil works well to loosen grease and grime.
1 - 8 of 8 Posts
