1 - 8 of 8 Posts
I am in need of new throttle cables for my '07. The Yami dealer wants about $120 for both cables. I found at PhatPerformace a SET of Baron throttle cables for $83, not counting the discount. Ill prob pick up the K&N filters while im there as well so I can get the % off.
What is your opinion on the Baron cables? Id like to spend less, duh, but if OEM is better quality ill pay the higher price. I am also in need of the air cover for the right side. If any1 has replaced theres and still has the OEM cover, Id be willing to purchase it from you. Thanks guys/girls.
Have u checked ebay. And your yama dealer is screwing the pooch list is 20$ apiece with tax if i wasnt on the road i would give u part # and exact cost one is 16.95 and the other one is 18.95 bought mine last year frm local dealer.
Are you kidding me? Thats getting your bang for the buck. Ill check out ebay, thanks for the insight.
Throttle cables, like clutch cables, are model-year specific. For 2002-2003 look in 'Popular Mods' under cables.
These are the factory throttle cables for 2007 model year:
CABLE, THROTTLE 1 is part# 5PX-26311-30-00 $44.47
CABLE, THROTTLE 2 is part# 5PX-26312-30-00 $40.34
Vendor: http://www.staryamaha.com/default.asp
These are the Barnett cables for 2007 model year:
102-90-30012 Throttle (Pull) $ see below
102-90-40012 Throttle (Push) $ see below
Factory: http://www.barnettclutches.com/products/cables.aspx
Pick a Local Vendor: http://www.barnettclutches.com/locator/search.aspx?type=state&state=IL
Barnett cables are also available at many on-line vendors. They are great cables.
Hope this helps
These are the factory throttle cables for 2004-2008 model years:
... Got to challenge you on this one Arizona Warrior as you haven't done your homework
Model Years 2002-2005 all share the same Black Push/Pull Throttle Cables because of supersession
Throttle 1 = 5PX-26311-20-00 (replaces5PX-26311-10-00) @ $16.50
Throttle 2 = 5PX-26312-20-00 (replaces5PX-26312-10-00) @ $18.49
Model Years 2006 & up have the more expensive braided stainless cables
The Braided Yamaha aftermarket cable can be purchased as well for all years:
BRAIDED STAINLESS STEEL - Throttle Cable Set from MSSS.com
STR-5PX48-10-SD @ $73.91
Yep.Its changed BACK (above) to just 2007 where it started.
The cable pricesabove are for the needed2007 cables on that website shown.
These are the OEM cables from the Yami Parts website:
Throttle Cables - '02-'03: 5PX-26311-00-00 and 5PX-26312-00-00
Throttle Cables - '04: 5PX-26311-10-00 and 5PX-26312-10-00
Throttle Cables - '05: 5PX-26311-20-00 and 5PX-26312-20-00
Throttle Cables - '06-'08: 5PX-26311-30-00 and 5PX-26312-30-00
Thanks Alan and Arizona, that price even beats the one I found. Thanks for the help! The msss.com website thought took me to some science website.
No problem.
The 'msss.com' website is shorthand for http://www.motorsportssuperstore.com/its the link at the top-right of your screen. They are a site supporter. Either http://www.motorsportssuperstore.com/or http://www.yamahasportsplaza.com/(their newer site is http://www.staryamaha.com/) tend to have the deepest discounts for Yamaha parts, plus the fastest shipping and the most information on their websites. One difference, they have extra discounts at different times.
I didn't order from msss for awhile but I just placed an order for a S* (Speedstar) AIS Scoop because a lot of members have been having very good luck with them being speedy. Up to then I've ordered all Yami oem parts and some other items from yamahasportsplaza and the prixes are mostly the lowest and the parts arrive very fast. Plus they communicate well.
IMO don't count out the Barnett cables. They have stronger more flexible cable sets. Their stainless outer cover looks nicer IMO too so if you change the throttle cables you'll probably want to change the clutch cable at some point. Because the Barnett clutch cable actually slides smoother it makes your clutch easier to activate. This becomes handy when you get around to upgrading to the Barnett SR2 clutch spring which feels heavier and grabs a lot better.
1 - 8 of 8 Posts
