1 - 4 of 4 Posts
just did my oil change
it didnt take more than 3 qts and its full
a little too full ,is that ok?You did not drain all the oil. you have an oil pan and an oil tank. There two seperate drain points. Search......plenty of info covering this topic. Including how to drain oil and how to properly fill.
Do a search.
You'll learn a lot.
But, in the meantime, oil+filter = drain, remove/replace filter...
put in 4, run the engine for a couple of minutes, shut it off and add a fifth.
The bike takes five with a filter.
Check this thread. It sounds like you didn't drain enough oil. It takes full 5qt.
http://www.rswarrior.com/forums/topic.asp?TOPIC_ID=785
Regarding the oil change -- Sorry bud, add about 3, run the engine, then top to 5. I said add four... that will be too much. Hopefully you didn't have an overflow with my original "how-to." If so, I owe you a quart. By: JimB............
1 - 4 of 4 Posts
