1 - 6 of 6 Posts
So I read what everybody said to do in order to launch these bikes. Now I'm a noob to really launching, but I reved it to 2000rpm or so and popped the clutch and my rear end just shifted sideways from spinning and then I let off the gas and once it quite spinning I was able to carry on. So am I doing something wrong or what?
Work the clutch also, that's the key. Don't just pop the clutch. Let it out fast but dont.kust let go of it.
Feather the clutch out as throttle is applied when the clutch is all the way out the throttle should be pinned.
Ride for a few minutes between launches to cool the clutch plates.
Well at the track I launch at around 4500 rpm and it's one smooth motion. Let it out quick but make sure to keep up with the throttle as well and she will go like a bat outta **** my best 60' is a 1.5 doing it this way. Just need to be fluid with it don't dump it.
1.5!!! Nice! My best 60' is a 1.8080. I try to launch about the same RPM, maybe 500 less. Looks like I need to work on it some more. What are you using for a back tire?
1 - 6 of 6 Posts
