turn signal loading
1.3K views 11 replies 5 participants last post by  amospro
Does anyone know what the turnsignal loading is supposed to be on a warrior? A while ago i installed the md wright kit on the rear. It was on for a while, no issues at all.
Recently i replaced the stock fronts with the Kuryakyn bullet leds on the front. They blink a bit faster now. I installed the Kuryakyn load equalizer that was included but i think that was specific to HD's. I have heard about improper loading messing with the ECU. Do you think that as long as there is some load, i am fine, or should i try to match it up properly?
#3 ·
The best solution I have found on other bikes is to replace the stock thermal flasher with an electronic flasher. This should work on a Warrior as well. All you need is a Tridon EL-12 or EL-12C. This will solve the fast flashing that is caused by the low amperage draw of the LEDs (basically it makes it think there is a bulb burned out).
#6 ·
It's just an electronic flasher that replaces the stock thermal one. You should be able to get it at Auto Zone or the like. It will solve the fast flash for sure, but I don't know enough about Warriors (yet) to know what the amperage draw of the signals does for the ECU. I can't see why the ECU should care what amperage the signals are drawing, but again I don't know enough about how they are designed to make a call on it.
AE1 at VQ-4 in Oklahoma City... /emoticons/emotion-2.gif
#7 ·
I'm experiencing the same problem. I just installed the Kuryakyns in the front with the supplied load equalizer and the ECU still doesn't like it. I'll be looking into this myself. Please post up if anyone has proven solutions.
AirNavy, I'm not sure if that will work with the warrior's ECU.
