21 - 22 of 22 Posts
avbon tire and swingarm from BMS but there is a lot more to it than that. You have to extend out the rear sprocket, you need a new front sprocket your drive chain will have to sit outside the frame so you will need a new front sprocket cover with built in bearings or you will have to go to a custom sprocket set up built into your swing arm which means usually at least an 8 inch stretch. You need a 12 inch rim etc. I would suggest sticking to 280 with Kyle as it is a tested and true product.
21 - 22 of 22 Posts
