1 - 9 of 9 Posts
Just bought a 2002 warrior that does not have any turning signals. Wtb aftermarket or stock turning signals. Thanks in advance.
I just put on some Kuryakyn LED silver bullets mounted to the fender stays and I absolutely love them, combined with a swingarm mounted license plate or Justice's radius mount it will clean up your rear end %110. A little pricey but much worth it. Check out the 1610 small ambers on www.kuryakyn.com. I Do still have the hideous stock rear signals if your interested.. Also go to your local Cycle Gear if you have one. They have several small turn signalsfor $15-$40 www.cyclegear.com
Just checked to see if it has the integrated brake light / turn signal. The brake light works but the turn signal is not in it. How much do you want for the stock front turn signils?
1 - 9 of 9 Posts
