41 - 60 of 146 Posts
Riken Raptor ZR, 245/45/17
Easy to get used to, go for it.
Stock rim and swing arm? I barely got a 235 on mine and only had 1/8" room left on the underside of my swing arm.
my tire is getting mounted sat afternoon i really hope it fits, with no issues.
does anyone with a ct have any issues while riding with a passenger?
It's probably not bad with a passenger, most likely because you wouldn't be driving "crazy" with someone on the back. But I must admit... I'm not as anxious as others to recommend going to a CT. They do have some handling issues. Take your time and get used to it.
Non at all with both my bikes unless your lowered.
just gotta get the psi right now.
On that tire I had it between 32-36psi but you have to have it to where it feels better for you.
i have done 67 miles on my new deinte d7 225/45/17. i love it! i can not say it is better or worse it is just different, i can get used to it
Discussion Starter #58
Just had my first 2 up ride after the c/t rear put on, and am thinking I will have to trim off the rear turn signal tabs. It rubbed a bit going over a rough RR crossing but handled really well. It has me wondering just how far I can push it in the corners. I have about a 1/2" scuff mark till the edge of the sidewall.
You shouldn't have to do that. I have a 235/45 on mine and was lowered but installed a 1000lb spring. Joey has a 225/40 and is slammed almost 2.5" but has a 1100lb spring
