Update legends forward controls
1.2K views 12 replies 9 participants last post by  Brit_Warrior
I just ordered a set of forward controls. Is there anything I need to watch out for while installing them? Any tricks or are they a straightforward install? I'm pretty handy just need to know if I need any special tools or something special to look out for.
I just got my controls. Hard time putting them on with missing hardware.
Did everyone get the bolt that holds the new shift linkage adapter to the controls?
Did you get a stainless cable or a brack cable?
Did you get hardware to mount the cable to the frame?
Did you get bolts to mount the horn to the new plate?
Did you get new bolts to mount the controls to the frame?
Just A few qiestions.
#2 ·
Yes, make sure the plunger adjustment is "CORRECT" the Legends does not come with Instructions on how to install or adjustment.....you want to make sure you have a decent 1/4 pedal freeplay in the brake lever....if the plunger is not properly adjusted it will not allow the brake fluid to return to the master cylinder thus causing the rear brakes to be constantly on, eventually melting the pads to the rotor....I have the Legends and learned the hard way.....the rear brake pads are still on back order....
#8 ·
quote:Originally posted by islecruiser
Also use loc-tite on every bolt with them.Some have had problems with bolts vibrating loose and loosing them.
I'll back up what Islecruiser says, take all of the bolts out and locktight them back up again, a few of us have lost bolts recently.
I had to get the Extended Shift & Brake Pegs as I found it difficult to reach the shifter pegs (they sit close in to the bike from where my feet are placed). If you're gonna buy them then get them straight from Legends at about $24 each as opposed to $32 each from Phats. They only give about an extra 1/2 inch but it's enough.
You'll also find threads on here about the brake cylinder leaking around the rubber seal, I haven't had this problem but some other guys have. The solution appears to be not to over tighten the filler cap so that the seal is 'squashed' out, just do it up nice and firm.
Enjoy them Gunny, I love mine.
#11 ·
Instead of buying the 1/2 inch wider shifter peg, I made an aluminum mounting spacer an inch wider. Took the stock one, traced it out on a block of aluminum that was an inch wider than stock, cut it out, shaped it on my bench sander and polished it. No one even notices that one side is wider than the other and now my leg does not have to curl around the left side air scoop. BTW, I only had to do it to the left side since I have removed the aircleaner and installed a BAK.
#12 ·
As far as the locktite goes, I've made it part of any assembly that I do on my bike. Does everyone think that the pegs need to be longer? The ones that come with the controls are longer than the Yamaha billet ones (which I will be selling when I get my new ones).
#13 ·
Definately but try them out first as it will depend on your height and whether you still have the stock boxes on both sides. Like VReater I have the VBAK so the right side is fine, I still have the stock box on the left though and find that I have to curl my leg around it to get to the controls as they are further forward and closer in to the bike than stock. Another way around it would be to add additional spacers between the controls and the frame to bring the controls out a bit. You would need longer bolts though.
