1 - 11 of 11 Posts
Ok I did a search here for anything on valve adjustment, found nothing. I think I'm right in the fact that this beast has hydraulic lifters but that doesn't mean there isn't an adjustment. I'm getting a noise that sounds like valves when the bike is HOT! Could it be valves or maybe the starter clutch, this noise comes from the front of the motor, I use Mobil One V-Twin oil maybe I should be using something else, I have also noticed that I have a noise when its cold for a bit then this goes away, Im thinking for sure that's the starter clutch, How hard is it to change that clutch? Thanks in advance for any help
Lifters are hydraulic.
Each rocker arm shaft has 2 arms to operate 2 valves @ a time by 1 pushrod. One arm has an adjustment the other does not. The adjustment is to balance the 2 valves. There should be a how to by this author on the forum if it still exists
To find engine noise: If you do not have a mechanics stethoscope use a long screwdriver with the handle stuck in your ear. Engine running touch the blade around the engine to determine the noisy area.
Hi. I found your post from 2006 via google. I searched because my new to me '05 with BAK has a 'miss' at lower revs when hot and backfire between gear shifts. The dealer said they all do that with bak but i reckon it shouldn't. It's now done 66700 kms. I read somewhere it could be valves need adjusting. I think it's not fuel related because it occurs with Power Commander both plugged in and disconnected. Any thoughts on this?
Hey bro start a new Tread with the issue that ur having..
It'll get more attention that way, and you'll get better help.
Also I dont believe that the valve's needing adjustment will , cause your issue..
Post up all mods that ur warrior has
So we can be of more help.
The backfire between shifts is partly normal and partly managable via fuel manager tuning, IVAN's ECU Flash, and AIS-blockoff. Your symptoms are 99% NOT valve related. The miss at low RPM is because your warm idle is too low, or it is fuel manager related.
Search criteria:
Ivan ECU
AIS Block Off ( or -AIS)
Hesitation off idle
Backfiring
Popping
Power Commander Tune
Maps
Suggest using the Google search field on top of many Forum pages. Or from browser use the search criteria RSWarrior: (plus a selected criteria from above). Example is RSWarrior: maps. This work will fuel your search imagination too, so is worth your time!
Hope this helps
This^^^^ + check the basics first.
How old are the spark plugs? Get new & gap @ .032 SAE.
The plastic spark plug wire boots screw onto the metal core plug wires insure that they are tight.
Crimp the primary coil wire female spades for a tight fit.
Hey all thanks for tips. I changed the plugs recently but didn't check the gaps. Will do that first then follow up check PC settings. I dont have cables or program for it yet but will check the link provided. It runs great on the highway just when its hot stalls when taking off. Has ais removed k&n pods i think and bub jugs shorts with baffles, the baffles ends are cut off so fairly open. The symptoms were present before that though. I run 95 ron mostly. We have 91,95,98 ron here. E10 is 94 but will never run it. I'll start with plugs and keep you updated.
Check your idle setting. 950 when hot.
Thanks yes it's about 950 to 1000 when hot. The dealer had it lower around 650-700. I had also blocked off the LCV for a couple of days but all that did was improve fuel economy.
1 - 11 of 11 Posts
