1 - 10 of 10 Posts
New, and you guys know your stuff. Want to change stock exhaust with V&H Pro Pipe and PC3. Any other purchases to make so it doesn't turn out half ass?
Any other "heads up"?
Thanks
Agreed with Mac. Also, some folks such as myself have a problem with the propipe endcap breaking loose from the pipe. Can be a major PITA in my opinion. Myself as well as others fix this by purchasing the hellrisers endcap for HD propipes. Takes a little modification to get it to fit the metric version. I say this to inform you of the setbacks with the propipe. Many RSWarrior vets love it, I wish I had of gone a different route. The yamaha speedstar pipe doesn't have any problems that I'm aware of, and it also will not scrape in hard right turns as the propipe will. Just my 2 cents. Thought you might want to know about propipe since you made the 1/2 a$$ comment.
I'm with Leetp, I have the ProPipe and my end peice let go once to. I fixed the problem with a V&H SS2r. If your curious check out my gallery, I put a small joiner pipe that kicks the muffler up a bit and have had no problems since, and it has alow growl, sounds cool.
Back to your question, BAK, PC111 and pro pipe and you have done HEAPS. Need a map and hang on tight when you twist that grip. It'll take a month of Sundays to get the GRIN off your dial.
Oh, I almost forgot, Welcome to the forum.
I also have a pro-pipe.
Blew 1 baffle . Got a new baffle from v&H , welded it from day 1 and 20,000 km later.. Still good to go !
Kyle
Thanks for all the help guys. Have looked at the speed star pipes. Any problem using them with the PCIII? I will change air intake also. A little leary of not using other speed star changes. Don't want to adversly effect the bike.
No problems using speed* with pc111 and no other changes. Also, do a search for "perfect pc111 install" before you install it the way the instructions say. Doesnt take but a few extra minutes and is worth the work. Do the perfect install before you have a custom map made. You will also want to do the AIS block off. This will help with backfiring with any new pipe and allowing for your custom pc111 map. I have these mods done and have about 85hp and 114ft/lb.
Hey Mac, I pretty sure I blew the baffle on my PP this last weekend, it rattles a little at certain rpms. How much welding was needed to replace the baffle, and how responsive was V&H with sending the replacment baffle?
Thanks
It was pretty easy getting for the replacement..
I hear it gets tougher every time though..
The welding is pretty easy - add a chunk metal, to stif'n the two screw tabs..
Kyle
Update on replacing the baffle....
Not neccessary (thank god!!!). I removed the baffle only to find that one of the mounting screws had come out and that caused the rattle I was hearing. While removing the baffle, I insured the fiberglass was in adequate condition and placed the original part back in the propipe. All is well, once again. Total cost of this repair $1.47 [8D]
BTW, I started the bike w/o the baffle and DAYUM that sounded nice.[/emoticons/emotion-2.gif] I was tempted to leave the baffle out, but decided against the idea until I acquire a new map for my PC-III.
1 - 10 of 10 Posts
