Stock air, is a big air box that sits on top of the throttle bodies, and is connected to to outside air box. It helps silences engine noise, but is restrictive on air flow. A V-BAK, you remove the air boxes, put Velocity stacks on top of the throttle bodies, with K&N air filters attached. You get more air flow, which means more power and better throttle response. You will hear more engine noise, but a new pipe will take care of that. Cation though, if you start doing this sort of thing, it will unleash the modaholic inside of you, and it will be hard to stop.
