1 - 20 of 46 Posts
2008 Survey part 1 of 4:
Year
Light Mfg CA=Clear Alternatives MD=MD Wright CD=Custom Dynamics UFO=HighTech UFO
Months On Bike
Came ready to bolt on
Mod to stock tail light needed
Sent out for that Mod
Used OEM Light for a Core
Did Mod to Light at Home
Kept OEM Light as spare
Flash rate same as OEM
Need resistors for OEM flash rate
Needed resistors came with the light
Posted by Member:
2002
CA Clear
36
Y
N
N
N
N
Y
N
Y
Y
slngshott
2002
CA Clear
18
Y
N
N
N
N
Y
Y
N
Y
Vladens
2002
CA Clear
12
Y
N
N
N
N
N
N
Y
Y
Shawnzilla
2002
CA Clear
6
Y
N
N
N
N
Y
Y
N
Y
swany1214
2003
CA Clear
19
Y
N
N
N
N
N
N
Y
N
ArizonaWarrior
2003
CA Clear
2
Y
N
N
N
N
Y
Y
N
Y
Kdub
2004
CA Clear
9
Y
N
N
N
N
Y
N
Y
Y
HeavyD (1st)
2004
CA Clear
10
Y
N
N
N
N
Y
N
Y
Y
HeavyD (2nd)
2004
CA Clear
24
Y
N
N
N
N
Y
Y
Y
N
Judge2008
2004
CA Clear
4
Y
N
N
N
N
Y
N
Y
N
oldmaxer
2005
CA Clear
12
Y
N
N
N
N
Y
N
Y
N
Ken (Big Shasta)
2005
CA Clear
12
Y
N
N
N
Y
Y
N
Y
N
Scootman
2007
CA Clear
7
Y
N
N
N
N
Y
N
Y
Y
Siradude
2007
CA Clear
4
Y
N
N
N
N
Y
N
Y
Y
NorCalWarrior
2008
CA Clear
6
Y
N
N
N
N
Y
Y
Y
N
Scott Dailey
2005
CA Smoke
1
Y
N
N
N
N
Y
Y
N
Y
darken_rahl03
2002
CD / Custom
6
N
Y
N
Y
Y
N
N
Y
N
tostyj
2002
CD / Custom
12
N
Y
N
N
Y
N
Y
Y
Y
RaySDF250
2003
CD / Custom
36
N
Y
N
Y
Y
N
N
Y
N
ekmaint
2005
CD / Custom
35
N
N
N
N
Y
N
N
Y
N
AkitaDog
2002
CD / McCoy
72
N
Y
N
Y
Y
Y
N
Y
Y
Independent_Lemming
2005
CD / McCoy
24
N
Y
N
Y
Y
Y
N
Y
Y
Independent_Lemming
2002
MD Wright
8
Y
Y
Y
Y
Y
N
Y
Y
Y
Tomasa
2003
MD Wright
19
Y
Y
Y
Y
N
N
Y
N
Y
Pep
2004
MD Wright
6
Y
N
Y
N
N
N
N
N
Y
ram396
2004
MD Wright
8
Y
Y
Y
Y
N
N
Y
Y
Y
doubledown
2005
MD Wright
18
Y
Y
Y
N
N
N
Y
N
Y
Warrior4Him
2006
MD Wright
12
Y
Y
Y
Y
N
N
Y
Y
Y
Youngja
2006
MD Wright
2
Y
N
N
N
N
Y
Y
Y
Y
06_warrior
2008 Survey part2 of 4:
Year
Light Mfg CA=ClearAlternatives MD=MD Wright CD=Custom Dynamics UFO=HighTech UFO
Tail light brightness 1=dimmer 3=same 5=brighter
Brake light brightness 1=dimmer 3=same 5=brighter
Signal Brightness 1=dimmer 3=same 5=brighter
Also have stand-alone signals installed
Posted by Member:
2002
CA Clear
3
3
3
N
slngshott
2002
CA Clear
1
1
1
N
Vladens
2002
CA Clear
3
3
1
N
Shawnzilla
2002
CA Clear
3
3
3
N
swany1214
2003
CA Clear
5
5
3
N
ArizonaWarrior
2003
CA Clear
3
3
3
N
Kdub
2004
CA Clear
5
5
5
N
HeavyD (1st)
2004
CA Clear
5
5
5
N
HeavyD (2nd)
2004
CA Clear
3
3
3
N
Judge2008
2004
CA Clear
5
5
3
N
oldmaxer
2005
CA Clear
5
5
3
N
Ken (Big Shasta)
2005
CA Clear
Discussion Starter · #2 ·
Vote Here! #2-2008: Integrated Tail Lights (Form Used for Survey)
Survey Form:Feel free to add your survey form into this topic even if its after the close date!
______________________________________________________________________________________
Year Warrior:
Light Manufacturer:
Light Model:
How Long Installed:
Complete ready to bolt-in unit? Y N
Were any mods to Stock Tail Light needed? Y N
Did you send your tail light out for modification? YN
Was the stock tail light required as a core? Y N
Did you mod the stock tail light at home? Y N
Did you save the stock tail light in event needed? Y N
Do the integrated signals blink at stock flash-rate? Y N
Are extra resistors needed to maintain flash rate? Yes or No
Are load equalizing resistors included in the price? Y N
Is the tail light at least as bright as stock? 1=dimmer than stock 3=same as stock 5=brighter than stock
Is the brake light at least as bright as stock? 1=dimmer than stock 3=same as stock 5=brighter than stock
Are the signal lights at least as bright as stock? 1=dimmer than stock 3=same as stock 5=brighter than stock
Did you also keep any stand-alone rear signals installed? Y N
Are any rear fender (or other) mods needed to mount? Y N
Installation Rating: 1=Difficult 3=Not too bad 5=Easy
Installation Time: 1=over 1 day 3=about 4 to 8 hours 5=under 4 hours
Quality: 1=Stops Working Sometimes 5=Same as stock
Maintenance Rating: 1=too much work 3=some maintenance needed 5=same as stock
Other Comments:
Re: Please Use This Survey Form
Arizona Warrior said:
Survey Form: (hit this REPLY button then hit QUOTE button to insert your responses and participate)
Year Warrior: 2003
Light Manufacturer: Clear Alternatives (CA)
Light Model: Warrior
How Long Installed: 3 years
Were any mods to Stock Tail Light needed?N
Did you send your tail light out for modification?N
Was the stock tail light required as a core? N
Did you mod the stock tail light at home? N
Did you save the stock tail light in event needed?N
Do the integrated signals blink at stock flash-rate? N
Are load equalizing resistors included in the price? N
Is the tail light at least as bright as stock?5
Is the brake light at least as brights as stock?3
Are the signal lights at least as bright as stock? 3
Did you also keep any stand-alone rear signals installed? N
Are any rear fender (or other) mods needed to mount? N
Installation Rating: 5
Installation Time:5
Quality:5
Maintenance Rating:5
Definition: Do you do more to keep this working and looking good than for a stock light?
Make any further comments here:
Never a single problem. I wish the signal lights were brighter in direct sunlight.
Year Warrior: 2005
Light Model: Warrior Intergraded sequential W/ smoke len
How Long Installed: 1 month
Was the stock tail light required as a core?N
Did you mod the stock tail light at home?N
Are extra resistors needed to maintain flash rate? No
Is the tail light at least as bright as stock? 5
Is the brake light at least as brights as stock? 5
Are the signal lights at least as bright as stock? 5
Installation Time:5
Quality: 5
Maintenance Rating: 5
Re: Vote Here! #2B: Integrated Tail Lights '08-'09
The quality of integrated tail lights has changed. I hope you'll please participate in this revision of the prior survey (see http://rswarrior.com/forums/t/48410.aspx).Like before, please follow this format so yourresponses can be included in the results chart. This was among the longest of the surveyslast time, so I spaced it out this time.
For Speed: reply to the post below becauseit'sset-up so you can hit that REPLY button thenhit theQUOTE button to insert the blank form into your post!
Year Warrior: 2004
Light Manufacturer: CA
Light Model: Integrated
How Long Installed: First one 9 months, second unit 10+months.
Complete ready to bolt-in unit? Yes
Were any mods to Stock Tail Light needed? No
Did you send your tail light out for modification? No
Was the stock tail light required as a core? No
Did you mod the stock tail light at home? No
Did you save the stock tail light in event needed? Yes
Do the integrated signals blink at stock flash-rate? No
Are load equalizing resistors included in the price? Yes
Is the tail light at least as bright as stock? 5=brighter than stock
Is the brake light at least as brights as stock? 5=brighter than stock
Are the signal lights at least as bright as stock? 5=brighter than stock
Did you also keep any stand-alone rear signals installed? No
Are any rear fender (or other) mods needed to mount? No
Installation Rating: 5=Easy
Installation Time: 5=under 4 hours
Maintenance Rating: 5=same as stock
Make any further comments here: When this unit fails, I will purchase an MD Wright unit.
Year Warrior: 2007
Light Model: Clear Alternatives Clear Integrated
How Long Installed:7 Months
Were any mods to Stock Tail Light needed?No
Did you send your tail light out for modification?No
Was the stock tail light required as a core?No
Did you mod the stock tail light at home?No
Do the integrated signals blink at stock flash-rate?No
Is the tail light at least as bright as stock? 3
Is the brake light at least as brights as stock? 3
Did you also keep any stand-alone rear signals installed?No
Are any rear fender (or other) mods needed to mount?No
Installation Rating:5
Installation Time:5
Quality:5
Maintenance Rating:5=same as stock
Make any further comments here: First Light came originally faulty, a replacement was sent at no cost.
Year Warrior: 2007
Light Model: CTL-0079-IT
How Long Installed: 4 months
Do the integrated signals blink at stock flash-rate? Y (but you have to install a flasher module)
Quality: 5=Same as stock
Maintenance Rating: 3=some maintenance needed
Other Comments: Replace the cheap flasher module that comes with the tailight with a heavy duty 12V flasher from Autozone (about $10) since I've done that no issues
Year Warrior:02
Light Manufacturer: Custom LED (bought from Custom Dynamics)
Light Model: Warrior Integrated
How Long Installed: one season
Complete ready to bolt-in unit? N
Was the stock tail light required as a core? Y, I reused the lense and housing
Installation Rating: 2=kind of difficult. It's not that bad, but Ikept thinking that I must be destroying the lense as I was cutting.
Installation Time: 1=over 1 day (could be done in a day, I took my time 'cause it was winter)
Quality: 5+=Better than stock
Other Comments: Sweet light, really bright yellow blinkers, and gives you the sense of accomplishment that only a DIY can. I think the blinkers may be a little harder to see when the brake lights are on.
Arizona, nice survey. Suggestions: Include a question about the color of the blinkers. Also include a question about whether the blinkers are hard to see when the brake light is on.
Year Warrior: 02
Light Manufacturer: Clear alternatives
Light Model: clear integrated
Are extra resistors needed to maintain flash rate? Yes but not used
Is the tail light at least as bright as stock?same as stock
Is the brake light at least as brights as stock? 3=same as stock
Are the signal lights at least as bright as stock? 3=same as stock
Installation Rating:Easy
Installation Time:under 4 hours
Quality: Same as stock
Maintenance Rating: same as stock
Other Comments:I have had no problems with my light.I like the clean look wih integrated signals.I like the fast flash rate.
Year Warrior: 05
Light Manufacturer: Custom Dynamics
How Long Installed: installed November '05
Complete ready to bolt-in unit? No, Use original housing
Did you mod the stock tail light at home? Yes
Did you save the stock tail light in event needed? N/A
Do the integrated signals blink at stock flash-rate? No, I like the faster rate
Are extra resistors needed to maintain flash rate? N/A
Are load equalizing resistors included in the price? No
Is the tail light at least as bright as stock? 5=brighter than stock, solid light no individual led visable
Installation Rating: Easy, just requires cutting existing lens from back.
Installation Time:under 2 hours
Other Comments:I have had no problems with my light and would by again.
Year Warrior: '02 and '05
Light Manufacturer: McCoy but also sold by Custom Dynamics
Light Model: unknown
How Long Installed: 6years and 2 years
Do the integrated signals blink at stock flash-rate? ( N ) but I like the faster rate of flash
Installation Rating: 3=Not too bad
Installation Time: s 5=under 4 hours
__Would buy this set up again and again, a little difficult to cut light but after the first time the 2nd was a breeze________________________________________________
Year Warrior: '06
Light Manufacturer: MD WRIGHT
Light Model: INTEGRATED
How Long Installed:1 year
Complete readto bolt-in unit? Y
Did you send your tail light out for modification?Y
Did you save the stock tail light in event needed?NA
Do the integrated signals blink at stock flash-rate?Y
Are extra resistors needed to maintain flash rate? Yes prewired with mod
Are any rear fender (or other) mods needed to mount? Yes ( drilled clearance hole in bracket for brake blink enable/disable toggle provided)
Installation Rating: 4=Not too bad
Year Warrior: '02
How Long Installed:8 months
Did you send your tail light out for modification?I used their exchange program.
Did you also keep any stand-alone rear signals installed? N but unit is wired so all you have to do is plug them it
Installation Time: 5, maybe 1 hour
Quality: 5
Year Warrior: 2005
Light Manufacturer: Yamaha modified by MD Wright
Light Model:
How Long Installed: 1.5 years
Were any mods to Stock Tail Light needed?   Yes
Did you send your tail light out for modification? Yes
Do the integrated signals blink at stock flash-rate?  Yes
Are load equalizing resistors included in the price? N/A
Is the tail light at least as bright as stock? 3=same as stock
Is the brake light at least as brights as stock? k 3=same as stock
Are the signal lights at least as bright as stock?  ck 3=same as stock k
Installation Time: 5=under 4 hours (actual time was about 1 hour to remove and reinstall)
Other Comments: MD Wright's mod works great. No issues. Had CA integrated light...went through 2 of them. still have a new one in the box.
Year Warrior: Example 2004
Light Manufacturer: clear alternatives
Light Model:
How Long Installed: 2 years
Is the tail light at least as bright as stock?3 =same as stock
Is the brake light at least as brights as stock?3=same as stock
Are the signal lights at least as bright as stock?3=same as stock
Installation Time:5=under 4 hours
Maintenance Rating:3=some maintenance needed
The clear alternative lights have a bad design with the transistors. They are not supported and therefore with all the vibration break their solder joints. It is simple to open up the light and solder/ silicoln the transisters. takes about an hour to do and will prevent any further issues with the lights.
Year Warrior: 2005
Light Model:
How Long Installed: 1 year
Other Comments:
Year Warrior: 2006
Light Manufacturer: MD Wright
Light Model: Integrated with "Flash Alert"
How Long Installed: 2 Days
Are extra resistors needed to maintain flash rate? Y (pre wired with mod)
Installation Rating: 1 (piece of cake)
Installation Time: 5 (less than an hour)
Quality: 5
Maintenance Rating: 5 (one word "quality")
In order to do the exchange program your tail light has to be in excellent condition which mine's was not. They ordered me a new one and intalled the mod. This mod comes with "Flash Alert" where when you apply your brakes the brake light keeps flashing continous until you stop applying the brakes. It's a great safety feature. There is a switch on the back of the light for the flash alert. You can switch it to either flashing or a steady brake light. They are very nice people to work with. I emailed them a question and in no time came back with an answer. I would recommend them to anyone.
Year Warrior: 2003
Light Manufacturer: custom dynamics
Light Model:
How Long Installed:3 years
Complete ready to bolt-in unit? n
Were any mods to Stock Tail Light needed?y
Was the stock tail light required as a core? y
Did you mod the stock tail light at home? y
Quality: 5, for under 100 mph
1 - 20 of 46 Posts
