DIMENSIONS
Length
Seat Height
Laden 1
Unladen
Ground Clearance
Rake Steering Head/Trail
Wheelbase
Track Width
Fuel Capacity
Oil Capacity
Weight
Dry Weight
Running Order
Luggage Capacity
Volume
Weight
U.S. UNITS
92.8 in.
25.6 in.
26.7 in.
4.80 in.
34° / 5.60 in.
67.0 in.
N/A
5.0 gal.
4.5 qt.
640.0 lbs.
673.0 lbs.
N/A
N/A
POWERTRAIN
Engine 2
Displacement
Bore x Stroke
Engine Torque 3
Fuel System 4
Compression Ratio
Miles per Gallon 5
ESPFI
Primary Drive
Gear Ratio (overall)
1st
2nd
3rd
4th
5th
6th
Liquid-cooled, Revolution®, 60° V-Twin
76.28 cu. in.
4.13 in. x 2.83 in.
86.00 ft lbs @ 6500 rpm
Electronic Sequential Port Fuel Injection (ESPFI)
11.5:1
42 hwy / 34 city
Gear, 117/64 ratio
11.75
7.898
6.322
5.459
4.899
N/A
WHEELS/TIRES
Wheels 6
Front
Rear
Wheel Option
Tire Size
Front
Rear
Black, 5-Spoke Cast Aluminum
N/A
120/70ZR-19 60W
240/40R-18 79V
ELECTRICAL
Instruments
Indicator Lamps 7
Reverse Function
Electronic speedometer with odometer, time-of-day clock on odometer, dual tripmeter, fuel gauge with low fuel warning light and countdown feature, low oil pressure indicator light, engine diagnostics readout, LED indicator lights, tachometer
High beam, neutral, low oil pressure, turn signals, engine diagnostics, security system (optional), coolant temperature, low fuel warnings
N/A
CHASSIS
Brakes
Parking Brake
Lean Angle (per SAEJ1168)
Exhaust System
4-piston front and rear
N/A
32° / 32°
Satin chrome, straight-shot side pipes
COLOR OPTIONS
Vivid Black; Dark Blue Denim; Red Hot Sunglo (New); Brilliant Silver (New)
PRICING 8
MSRP
Black
Color
Two-Tone
Custom Color
Security
Wheel Option
ABS Option
Reverse Option
Cruise Control
California Emissions
Freight
$ 17,199
$ 17,504
$ N/A
$ N/A
$ 345
$ N/A
$ 795
$ N/A
$ N/A
$ 100
$ 330
Now compare the warrior and any other japanese bike and you come out on top.
