Status
Not open for further replies.
1 - 15 of 15 Posts
This area is a storehouse for Warrior Fuel Managers.
1. This Table of Contents
2. About PCiii and PC-V Cables, %Throttle, Map Files
3. reserved
4. Cobra Fi2000 PowrPro CVT #92-1772AT
5. Power Commander PC-V
6. Power Commander PCiii-USB (Ver 2 with TPS Plug)
7. Power Commander PCiii-USB (Ver 1 with TPS Crimp)
8. Power Commander PCiii-USB-EX (California)
9. Power Commander PCiii-Serial (PCiii) and (PCiii-R)
10. Power Commander PCiii and PCiii-USB Perfect Install Warrior
11. Cobra Fi2000 (non-autotuning models)
12. Vance and Hines Fuelpak 65005
13. Dobeck / Techlusion FI-2050ST
14. Warrior ECU-Bump
15. Warrior Dynatek Fusion
Modification Help Files: About PCiii and PC-V and their Fuel Maps and Cables
Attached Here:
PCiii-USB Cable (all models)
PCiii-USB Accelerator Pump Instructions
PCiii Setting Warm Idle (all models)
PCiii Setting 0% and 100% Throttle (all models)
PCiii and PC-V About Power Commander Map Values (PCiii shown)
Modification Help File: Power Commander 3USB (PCiii-USB) Ver 2 with TPS Plug
If using a PC3-USB this is the preferred unit.
Modification Help File: Power Commander 3USB (PCiii-USB) Ver 1 with TPS Crimp
Note1: See the Firmware Update instructions (attached) for firmware version numbers that need to be sent to Dynojet for firmware updating. The 'tools' needed to update some early versions at home may be unavailable.
Note2: This version does NOT have a TPS Plug and Dynojet no longer provides a retrofit so use the 'Perfect Install' method.
Modification Help File: Power Commander 3-Serial (PCiii) and (PCiii-R)
Note: Not supported by most modern dynotuning centers.
Modification Help File: Cobra Fi2000 and Fi2000r (non-autotuning models)
Note: This older unit has very limited tuning ability (investigate Cobra AT CVT model instead).
1 - 15 of 15 Posts
Status
