Status
Not open for further replies.
1 - 20 of 25 Posts
This area is a storehouse for General Warrior 'Maintenance & Repair' Help Files.
1. This Table of Contents.
2. Stock Turn Signal Bulbs by Model Year, plus UK notes. Replacing the Flasher.
3. Stock Warrior Tool Kits, 2002, 2003-2005, and 2006+, Plus Other Tools.
4. Changing the Motor Oil and Oil Filter, and Checking Motor Oil Level.
5. Changing the Transfer Case (Middle Drive) Fluid.
6. Changing and Adjusting the Drive Belt. Emergency Drive Belt.
7. Setting-Up the Warrior Before Tuning; Reading Spark Plugs.
8. About the ECU, Where it Lives, What it Does, Error Messages.
9. Disassembled Views of Some of the Parts that Differ by Model Year.
10. About the Fuel Tanks, Pump, Filters, Injectors, Dry Breaks, Low Fuel Sensor, Gas & Octane.
11. About the 'Exhaust Header' Gaskets and Options.
12. About the Wiring Under the Rear Fender.
13. About the Wiring in the Headlight Bucket and Replacing Bulb.
14. Photos of Various Uninstalled Component Parts - Group 1.
15. Photos of Various Uninstalled Component Parts - Group 2.
16. About the Wiring Under the Rider Seat and Fuel Tank.
17. About the Battery and the Circuit Fuses.
18. Adjusting the Warm Idle. Understanding LCV Issues.
19. Adjusting the Clutch Cable.
20. Yamaha Fastener Part Number Tips and Tricks.
21. Bedding and Re-Bedding Disc Brake Pads to Rotors.
22. About Spark Plugs. About Anti-Seize on Spark Plugs.
23. If You Lost Your Only Warrior Ignition Key.
24. MOCAL Oil Filter Union (Oil Filter Leak Fix)
25.
Service Help File: Stock Warrior Tool Kits.
1. Warrior OEM Tool Kits by Model Year.
2. Spark Plug Thread Back-Tap.
3. Craftsman Aluminum Motorcycle Jack.
4. Warrior OEM 2003+ Shock Adjustment Tool Dimensions.
5.
6.
7.
8.
9.
10.
Service Help File: Changing the Motor Oil and Filter, and Checking the Motor Oil Level.
Also See Attachments.
Checking the motor oil's level in your Road Star Warrior is different than you probably expect and not realizing this can be a little embarrassing in the forums. Please take a few minutes to view this Yamaha video at least twice because the procedure is important, and its different enough its worth a second look. If you own a Warrior then you want to know about this.
Please Click Here: https://www.starmotorcycles.com/star/service/viewservicetip.aspx?ls=star&yr=2003&lid=2&mid=61&tid=8
If you need replacement oil plugs, get them from Yamaha dealer locally or remove both of yours during an oil change and match at the local auto parts store for length. Oil plugs are 12mm with 1.5 pitch and 17mm hex head. Length could be standard or special, don't know.
Its possible to avoid the need to over-torque the steel oil plug into the aluminum motor by using new oil plug gaskets (washers) every oil change, or every second oil change if you want to keep track. They are 14mm aluminum oil pan plug gaskets. If buying online then verify quantity you are buying for the price. Avoid plastic/nylon washers they require lots of torque. Aluminum or copper are used by many, although some say to also avoid copper washers since the motor is aluminum (your call): http://www.berridge.com/Preventing%20Electrolysis.pdf
[Added} this is an updated link for the attached PDF for the JASO-MA 'wet-clutch' information and links to additional reading: JASO MA and JASO MB classifications - oilspecifications.org
[Added} two additional PDF files: JASO (use for wet clutch proof) and API (use for service grade proof).
[Added} Updated BOSCH 3323 and 3323ST oil filter dimensions (verify bypass valve psi for 3323ST).
[Updated Image Content}
252811
Service Help File: Changing and Adjusting the Drive Belt.
Also: Emergency Drive Belt.
(thanks to siradude for reducing some documents in filesize!)
See Attachment.
Service Help File:
Setting-Up the Warrior Before Tuning (and more).
See Attachments.
Service Help File: Some of the parts that differ by Model Year.
1. Seats.
2. Front Brakes.
3. Front and Rear Fenders.
4. Middle Drive and Front Pulley.
5. Shock Absorber.
6. Fuel Injection System Relay.
7. Turn Signal Bulbs and Lenses.
8. Rider Peg-and-Control Mounts.
9. Handlebars.
10. The Model Year Differences thread.
253497
Service Help Files: About the Fuel Tanks, Pump, Filters, and Low Fuel Sensor.
1. Fuel Pump Assembly and Low Fuel Sensor.
2. Main Fuel Tank Exit Feed, Screen, Seal.
3. Fuel Injector Sketch with Dimensions.
4. Fuel System Dry Break.
5. Brass Nipple Fuel Pump Nipple Repair.
6. Fuel Pump Info and Sketch.
7. Badly Repaired Fuel Tank Warning.
8. Aftermarket Fuel Pump Motor.
9. Fuel Injector Spray Pattern & Cleaning.
10. Octane Explanation and the Different Calculation World Wide.
1. Middle Drive Assembly
2. Transmission Gears
3. Main Drive Gear Set
4. Shift Shaft and Forks
5. Clutch Lever Orientation
6. Barnett SR2 Perfect Fit Fix (old)
7. Barnett SR2 Spring Ratings
8. Roadstar 5th Gear in 02-05 Warrior
9. Right Side Oil Tank Cover Rear View
10. Middle Drive Disassembled.
Discussion Starter · #15 · (Edited)
1. Ignition Security Screw.
2. Oil System Vent Hose.
3. Cams and Lifters.
4. Crank and Connecting Rods.
5. Heads.
6.
7.
8.
9.
10.
1 - 20 of 25 Posts
Status
