1 - 18 of 18 Posts
Congratulations to our Warrior of the Month for February, 2017
outlawarrior
About outlawarrior
Member Since 09-19-2010
Location South Dakota
Total Posts 623
Outlawarrior's Warrior
Model Year 2007
Color Charcoal Silver with Stripes
Size 1700
Modifications
Custom VBAC, K&N Filters with Outerwears pre filters
Barons coil relocation plate modified with Dynatek coils, MSD pro wires
Cobra Fi2000 PowerPro Tuner
Ground Switch for quick ECU bump tuning
12oClockLabs SpeedoDRD digital speedometer adjuster
Wiseco stock bore high compression 10.5-1 pistons, rings, pins
Speedstar Competition Camshaft Set with Orient Express springs
Btk572 Power Pipe
Hard Krome 3 inch headers cut off with custom stainless tips
Barnett Clutch Conversion Kit with MT-23-6 springs
Kylenv modified caliper relocation, swing arm and 9x18" rear wheel
Avon AV72 Cobra 250/40R18 rear tire or
Riken Raptor ZR, 245/45/17 car tire on stock wheel when I go Dark Side
Progressive Suspension 465-1158 465 Series 1 inch Lower shock/spring
Baron lowering block
31 tooth steel pulley
Custom nude pulley modification
Oil pressure gauge with custom mount
Banjo bolt brake light switch
Custom Stainless brake lines
Custom forward control relocation
Kuryakyn Stiletto pegs and pinned Stirrups
Yamaha heal toe shift arm
7000 Lumen LED Headlight
LED taillight conversion
Custom Dynamics Dual Intensity 3 inch front signal light bars
CustomLED ELFR-1 Electronic LED flasher relay
Chrome BMS Choppers 6 Degree Triple Trees
Yamaha TT Bars with Rail Style Grips
Wide Blade Chrome Levers with custom pivot bearings
Memphis Shades Bullet Fairing with easy on/off Bullet Booster
Low and Mean custom front fender
Chin Spoiler
Flush Mount valve stems
Ultimate Upholstery Solutions customized seat
V Star leather covered hard bags with custom quick attach mounts
Gremlin Bell
g]
Congratz outlaw ... Sweet warrior... I like everything that you've done to your warrior....
Sent from my Z831 using Tapatalk
1 - 18 of 18 Posts
