1 - 20 of 46 Posts
This is just my working list of tires for the Warrior.
Its not a complete list. Its purpose is to look at
each tire's actual dimensions for fitment purposes.
This includes wheel diameter and width for swingarm.
Warrior Rear Tire Options for Stock Fender:
OEM Dunlop D220 200/50ZR17
. Tire Width: 194mm = 7.64"
. Tire Diameter: 635mm = 25.00"
. Tread Depth: 6.5mm = over 8/32"
. Rim Range: 6" - 6.5" recommended
. Capacity: 853 pounds
. Weight of Tire: not listed
OEM Bridgestone BT020 200/50ZR17
. Tire Width: 201mm = 7.91"
. Tire Diameter: 631mm = 24.84"
Avon Storm 2 Ultra 200/50ZR17
. Tire Width: 203mm = 7.99"
. Tire Diameter: 630mm = 24.8"
. Tread Depth: 6.8mm = over 8/32"
. Rim Range: 6" - 6.5" (6.25" rec)
. Weight of Tire: 16.56 pounds (16 lb/9 oz) (7.51 kg)
Avon Storm ST 200/50ZR17 (discontinued)
. Weight of Tire: 16.5 pounds (16 lb / 8 oz) (7.5 kg) (post office scale)
Metzeler ME880 200/50ZR17-Bw (see Bruce59's comments below)
. Tire Width: 193mm = 7.60"
. Tread Depth: 6.3mm = under 8/32"
. Rim Range: 6" recommended
. Weight of Tire: 15.84 pounds
Shinko 009 Raven Radial 200/50ZR17
. Tire Width: 200mm = 7.87"
. Tire Diameter: 632mm = 24.88"
. Tread Depth: 5mm = 0.200" (under 1/4")
. Rim Range: ~6.25" recommended
. Weight of Tire: 15.2 pounds
Shinko 011 Verge Radial 200/50ZR17
. Tread Depth: 6mm = 0.235 (under 1/4")
. Weight of Tire: 16.0 pounds
Metzeler ME880 210/50ZR17-Bw (discontinued)
. Tire Width: 210mm = 8.27"
. Tire Diameter: 642mm = 25.27"
. Tread Depth: 5.5mm = 7/32" (under 1/4")
. Rim Range: 6" - 7" recommended
. Capacity: - 882 pounds
Metzeler ME880 Radial 240/40VR18-BW
. Tire Width: 9.41"
. Tire Diameter: 25.78"
. Rim Range: 8" to 9"
. Capacity: 963 pounds
. Weight of Tire: 17.66#
Pirelli Diablo Rosso II 240/45ZR-17 82W
. Tire Width: 235mm = 9.25"
. Tire Diameter: 648mm = 25.9"
. Tread Depth: mm = unknown
. Rim Range: 8" - 9" recommended
. Capacity: - 1,047 pounds
Dunlop Elite 3 Radial 250/40VR18-BW
. Tire Width: 10.02"
. Tire Diameter: 26.20"
. Rim Range: 9" recommended
. Capacity: 1,019 pounds
Avon Cobra AV72 Radial 250/40VR18
. Tire Width: 251mm = 9.9"
. Tire Diameter: 655mm = 25.8"
Metzeler ME880 Radial 260/40VR18-BW.
. Tire Width: 10.19"
. Tire Diameter: 25.98"
. Rim Range: 8.5" to 9.5"
. Capacity: 1,074 pounds
. Weight of Tire: 17.73#
Warrior Rear Tire Options for Wider Custom Fender:
Metzeler ME880 Radial 280/35VR18-BW.
. Tire Width: 277mm = 10.91"
. Tire Diameter: 655mm = 25.79"
. Rim Range: 9.5" - 10.5"
. Capacity: 1,102 pounds
. Weight of Tire: 18.23 pounds
Avon Cobra AV72 Radial 280/40VR20-BW (20" wheel).
. Tire Width: 281mm = 11.1"
. Tire Diameter: 732mm = 28.8"
. Capacity: 1,279 pounds
Metzeler ME880 Radial 300/40VR18-BW.
. Tire Width: 300mm = 11.8"
. Tire Diameter: 665mm = 26.2"
. Rim Range: 10" - 10.5"
. Capacity: 1,202 pounds
. Weight of Tire: 12.50 pounds
Avon Cobra AV72 Radial 300/35VR18-BW.
. Tire Diameter: 664mm = 26.1"
. Rim Range: 10" - 11"
. Capacity: 1,201 pounds
The conversion math: (8/32" = 1/4")
5.5mm = 0.218800" which is less than 8/32"
6.0mm = 0.236220" which is less than 8/32".
6.3mm = 0.248031" which is just under 8/32".
6.5mm = 0.255905" which is just over 8/32".
6.8mm = 0.267716" which is more than 8/32".
Why?
Tire manufacturers indicate minimum tread
depth in 32nd's of an inch, or in millimeters.
Date of Update: July 2011 by ArizonaWarrior
Note: please re-verify all dimensions!
Vendor
Dunlop RoadSmart - 200/50ZR17
LOAD/ SPEED INDEX: 75W
SIDEWALL: BW
PART#: 31RS-82
Tire Width: 7.68"
Tire Diameter: 24.88"
Tread Depth: 9/32"
Rim Range: 6" - (6.5" recommended)
Capacity: 853lbs @ 42psi
Dunlop RoadSmart - 190/50ZR17
LOAD/ SPEED INDEX: 73W
SIDEWALL: BW
PART#: 31RS-22
Tire Width: 7.52"
Tire Diameter: 24.76"
Tread Depth: 9/32"
Rim Range: 5.5" to (6" recommended)
And according to the Dunlop website, the 6" rim is recommended for the D220.
http://www.dunlopmotorcycle.com/tirecatalog_tire.asp?id=74
Vendor
Can we get some 190 tire sizes in that list as well? Probably have to get some of the guys to chime in with what they are running.
Vendor
Good idea. Plus the stock Dunlop is 194mm so not far off 190mm.
What 190's are good? Maybe you can post 'em in the same format.
If you guys come up with more rear tires it'll be just that much handier!
Would you like me to PM you with the info so you may post it in the 1st original post or just make another post in the same format? I will start tonight when I get home.
Discussion Starter #10
HAHA You Always Say That . . . no worries . . . it'll be great if you post 'em!
I wasn't thinking of making one big document. Maybe later if its helpful.
Vendor
I do... :( I just forget the PM part of the equation ha ha. I'll post when I have it all.
Shinko 011 Verge
POSITION: Rear
TIRE SIZE: 200/50R17
SPEED RATING: W
RIM SIZE: 17 in.
TIRE WIDTH: 200 mm
RATIO: 50
CONSTRUCTION: Radial
TREAD PATTERN: Sport/Touring
DESCRIPTION: 011 Verge Raidal
Also carry a 190 size as well.
POSITION: Rear
TIRE SIZE: 190/50R17
SPEED RATING: W
RIM SIZE: 17 in.
TIRE WIDTH: 190 mm
RATIO: 50
Discussion Starter #14
Hey Yamaweezle, does Shinko publish the tire OD and tread depth and all the other stuff like range of rim widths as shown for the other posts in this topic?
ref:
ref:
Sorry man...That was the best I could find as of last night. I didn't see that info on Shinko's site, but that doesn't mean it's unattainable. I'll do a better search when I get home from work tonight.
Discussion Starter #18
Yes I agree, I didn't find it either, so figured I'd ask. Too bad, I'd like to know the tire's actual width, OD, and tread depth, but even a crafty google search parameter doesn't yield anything. No problem.
Vendor
Michelin Pilot Road 2 190/50ZR17 (Dual Tread Compound 40%/20%40%):
. Tire Width (in use): 203mm = 7.99"
. Tire Diameter (in use): 636mm = 25.04"
. Tread Depth: 9/32"
. Rim Range: 6.00"
. Capacity: 805 pounds
. Weight of Tire: Not Listed
Michelin Pilot Road 3 190/50ZR17 (Dual Tread Compound 40%/20%/40%):
. Rim Range: 6.00"
Michelin Pilot Power 2CT 190/50ZR17 (Dual Tread Compound 11%/78%/11%):
. Tire Diameter (in use): 622mm = 24.48"
. Tread Depth: 7/32"
. Rim Range: 6.00"
Michelin Pilot Power "Super Sport" 190/50ZR17 (Mono-Compound 100%)
. Rim Range: 6.00"
Michelin Power Pure "Super Sport" 190/50ZR17 (Dual Tread Compound 40%/20%/40%)
. Tread Depth: 6/32"
. Rim Range: 6.00"
Bridgestone Battlax BT-023 Sport Touring 190/50ZR17 (Dual Tread Compound)
. Tire Width: 192mm = 7.56"
. Tire Diameter: 629mm = 24.76"
. Tread Depth: Not Listed
. Rim Range: 6.00"
Bridgestone Battlax BT-021 Sport Touring 190/50ZR17 (Mono-Compound)
. Tire Width: 194mm = 7.637"
. Rim Range: 6.00"
Bridgestone Battlax BT-020 Radial 190/50ZR17 (Mono-Compound)
. Tire Width: 188mm = 7.40"
. Rim Range: 6.00"
More to come, Continental is next up...
1 - 20 of 46 Posts
