Weird Noise: Revisited
1.3K views 14 replies 9 participants last post by  VR-4man
Still have this grinding kind of gear/bearing noise when I am slowing down to a stop. I get it when the clutch is pulled in while slowing down (in gear) and I also get it if I shift into neutral before stopping (clutch out). I don't get it if it is in gear with the clutch out.
Is it the clutch?
Oh, and it goes away after I've been riding for 20 minutes or more.
Baffled.
#4 ·
No recall yet. I'm waiting for my chrome! [/emoticons/emotion-1.gif]
Free play is about 1/4 inch measured at the lever mount. Clutch is working as it should, as far as I can tell. No clunking into gear and I can roll the bike backwards easily with the engine running, in gear and the clutch pulled in.
#5 ·
If you have proper freeplay in your clutch lever, it may be that the bolt(s) holding the friction plates together is/are loose. I had this happen around 2,000 miles, long before anyone had heard of the recall.
Some bolts weren't torqued properly one worked its way out and got knocked sideways, creating sounds like yo describe and screwing up my shifting.
Just a thought.
#7 ·
As others have said, you may not have enough free play in your clutch cable. After riding for about 20 minutes the cable will actually stretch a little and give you a little free-play, making the problem appear to go away. When we were riding through mainstreet at Americade, it was so hot and traffic was so slow, we couldn't make it halfway through before our clutch levers were flapping in the breeze.
I like to keep a heavy 1/8th inch of freeplay when cold.
#8 ·
VR, I had a weird noise like that come up one day. It sounded something like a ball rolling around inside a cylinder when I would pull the clutch in. The noise started up while I was out to lunch, got worse when I left the office headed for the shop. By the time I got to the shop to have somebody check it out, the noise had stopped altogether and I haven't heard it since.
