1 - 3 of 3 Posts
I am looking at some possible mods and need to know if the pitch is the same or different on the stock warrior pulley vs a harley pulley?
Some.
Warrior Belt - OEM:1-1/8" (28.575mm) wide, 14mm pitch, 130 tooth
Belt - Length - Various Pulleys: http://rswarrior.com/forums/t/25885.aspx
Drive Pulley - Front-to-Rear Ratio: http://rswarrior.com/forums/t/24106.aspx
Drive Pulley - Rear - HD 65 Tooth: http://rswarrior.com/forums/t/28927.aspx
Drive Pulley - RoadStar 1.5" Mod: http://rswarrior.com/forums/t/115394.aspx
From reading these you should come up with some good search criteria so you can target your search to what you are after.
Hope this stuff from the Popular Mods post helps you.
1 - 3 of 3 Posts
