1 - 13 of 13 Posts
Congratulations to our Warrior of the Month for October, 2017
Brizzman
Congrats!
About Brizzman:
Biography: USAF veteran
Interests: Riding, 'Wheeling, Camping, Hiking, Skiing, Boarding and other outdoor stuff
Occupation: ROWPU and HMDS Mechanic for DOD
Real Name: Brizz
Brizz's Warrior:
Model Year 2005
Color Black Cherry w/ flames
Size 1700 with Speedstar stage IV
Modifications:
Speedstar Stage IV
Wiseco 10.5:1 HC pistons
Yamaha Speedstar cams, lifters & springs
Speedstar high flow fuel injectors
Vance & Hines Big Radius exhaust
VBAK w/ K&N air filters
Barnett SR2 clutch plate with gold springs
Ivan's flash ECU for high compression engine
Dynatek Fusion
Dynojet Auto Tune (No O2 sensors in the new exhaust yet. Running Speedstar Auto Tune map.)
POD-300
Dyna DC2-1 Coils relocated under tank
8mm Dynatek plug wires and NGK DPR7EIX-9 Iridium plugs
Static timing advanced 2.5 degrees (file on trigger wheel)
Throttle bodies ported/polished and synched
Exhaust ports ported/polished
PCS progressive rate spring, 825 to 1250 lbs.
Ram's adjustable lowering links adjusted to raise rear end
S&S/Gates X3N carbon cord drive belt # 106-0359
Corbin Stinger seat
Cruiser Performance Punisher 1.5" diameter drag bars
Kuryakyn flame grips
KiWAV chrome skull mirror
Wide chrome hand levers
Braided brake hoses
Modified motor mount
Cyclops H4 3800 Lumen LED headlight
Battery Tender LiFePo4 battery, part # BTL14A240C
Rear reservoir removed
DuPont Silvervain powder coated wheels, rear pulley & hub
Justice Designs flamed right and left side engine covers
Justice Designs custom curved side mount license plate
Radiantz LED front and rear turn signals
Colder dry break w/stainless braided covered fuel lines and chrome clamps
FPR relocation underneath gas tank
Hidden rear caliper
S/S braided cables & fork cap covers
Chrome fork covers
Chrome fork stem nut covers
Chrome gas cap cover
Chrome timing cover
Chrome cam cover - flamed
Chrome drive belt covers
Chrome bolt head plugs
Chrome master cylinder cover
Chrome pulley nut covers
CAD polished tach housing
Billet shift linkage w/holes
Billet drive pulley case set
Billet drive cover - flamed
Billet frame covers
Billet clutch cover
Billet compression release cover
Billet rear rotor cover
Lower cowl
Front axle covers
Rear axle covers
Swing arm pivot cover
Mods on the to do list:
Replace handlebars with Yamaha TT bars
Quick Shifter
Shift light
More chrome
Accessories:
Memphis Shades Big Shot windshield, not installed
Cobra rear rack, not installed
Backrest and rack combo.
Saddlebags on Easy Brackets, on when needed, off when not
1 - 13 of 13 Posts
