A revisit of my last couple posts and my reply to your conversation-PM should tell you that at ~50km you should not expect permanent damage, and restoring the equipment to normal or plugging with block-off plates should be a priority (diy info was provided). I'm glad you talked about what you did, I think we will all sleep better tonight knowing we caught it before any harm could be done.
All that said, your geographic location is dryer and warmer and carbon fouling happens very fast in those conditions. Said another way, when there is adequate heat and dryness to harden the carbon deposits (which build thickness in coating layers) then trouble can happen quickly.
But you should not worry. Correct the conditions by putting all the hoses back so cool air flows in the correct direction. Or install purchased or DIY block off plates. Again, see instructions in Documentation (Table of Contents).
Relax. Before long we will have you thinking and working like a top hand wrench.
