1 - 9 of 9 Posts
Anyone have a set of baffled executioners they dont want let me know!
Not in a rush just curious if anyone has a set.
The Executioners are straight pipes, no baffles. They use torque cones for back pressure and pipe fitment. There not to loud except when you accelerate hard. I've had mine for a long time and still like them very much. They are to long for a lowered Warrior and scrape on right hand turns. I modified mine and shortened them 2 1/2" so they never drag. Good luck finding a used set as they are like hens teeth to find.
  • Like
Reactions: Chomorro
Well there goes my plan. I was reading they dont scrape in other threads but my bike is lowered that's why I was looking for a set.
Onto the next idea
Sorry my man, i just didn't want you to buy some and then find out like it did that your pipes would be damaged on the first right turn. lucky for me i have a tig welder and could fix mine so i could use them. Sucked though that i had to send them off to be re-chromed and i had to make a new rear mount. I'm sure you will find something you like that don't take all that re-doing to make them work.
I picked up a set of stock headers to play with so I just need to find a nice budget friendly slip on that looks good. Thanks for the heads up! I'm hoping my new 240 wheel will give me a little more rear clearance as well.
I've got the ProPipe n lowered warrior and dont scrap it....
And I have a 250....
Well I've actually scraped the frame....
Do a forum search for the 1256day..
He has a write up on a exhaust he Came up with using the stock header
Thanks desert! I will check it out
The leaderdeuce dream pipe looks awesome. His version of the 1256day pipe. I wonder if I can get someone to make me one
Yeah that's the one.
It was a collaboration between 1256day and some forum member's...
If done right it looks good ...
1 - 9 of 9 Posts
