1 - 2 of 2 Posts
XVS1100AC Dragstar Classic specs for flange bolts (x4) for the driveshaft hub to rear arm suspension
I'm after the specifications for the 4 bolts that secure the hub of the driveshaft onto the rear suspension frame. http://www.starmotorcycles.com/star/parts/home.aspx then navigate down the left side menu to "REAR ARM SUSPENSION" note items 7 and 8. These are the bolts and washers I refer to.
I was washing and cleaning my bike today after having been for a ride yesterday and noticed that the 4 bolts are missing. Just had new tyres fitted front and rear and it seems that the 4 bolts have come loose and were lost on my ride. (The bolts had been secured and tightened using a torque wrench, but cannot buy locktight here, so that wasn't done). As this type of bike is not sold here (I'm in mainland China) so going to the local Yamaha dealers will not be of any use... (thats a whole 'nother thread!!!) this means I'd have to buy from outside China and import the bolts and washers in... however if someone knows or can tell me the specs on the bolts in question I will shop around until I can find them here, as there are numerous small hardware type stores around. The cost of courier in will be more than the cost of the bolts and washers for sure!
90105-101A9-00 FLANGE BOLT x4
90201-112U0-00 FLAT (PLATE) WASHER x4
Re: XVS1100AC Dragstar Classic specs for flange bolts (x4) for the driveshaft hub to rear arm suspension
http://partsfinder.onlinemicrofiche.com/Alba/Yamaha_OEM/YamahaMC.asp?Type=12&A=382This site may help you.Complete brakedown of parts
1 - 2 of 2 Posts
