1 - 14 of 14 Posts
I'm considering purchasing the Yamaha mini fairing and I was wondering if there any restrictions to handlebar swap outs with the fairing.
Also, has anyone used flush mount turn signals in their mini fairing in replace of their stock turn signals?
Just put the mini fairing on last week. I have stock bars with Barons 2 up & 1&3/4 back (or verse visea) risers, no problems.
I have been looking for some flush fit turn signals to mount in the fairing, nothing has tripped my trigger yet. Got any links?
TIA,
Churchkey
TIA,
Churchkey
That is the kickback riser, correct?
quote:Originally posted by cabexbx
Thanks JD...did you use the stock risers with the bars?
Yes, I am running the stock risers. I plan on going with the Barons kickback risers in the near future.
Churchkey...I have the Ti so I was thinking I'd go with a carbon fiber look. Lockhart-Phillips has a handful of different applications. Go to Accessories and then there's a category for flush mount turn signals.
http://www.airtech-streamlining.com/miscairtech/turnsignals.html
TIA,
Churchkey
Hey Geestar, You are correct, Kickback risers.
Later,
Churchkey
cabexbx, If you decide to use LED's in the fairing, watch out, I have heard they are not very visable if they are viewed at an angle, that they show best if veiwed from perpendicular to the mounting surface. Check Bill1943 website, see his turn signal setups, he had his led's set parallel to his forks but had to change them. He make them vertical so they would shine directly at cars so they could be seen well. If you do put them in the fairing, I'd like to see a pic, I don't think anyone else has done this and posted a picture. Could look very clean.
Hey Cabexbx, Thanks.
Later,
Churchkey
Hey cabexbx, welcome and thanks for the links, some pretty neat stuff in there, mostly sport bike stuff but the accessories can be easily adapted.
? on the yamaha TT fat bar, saw a post but cant find it in search. what size hole on each side and are the bars clear to the top of the tree. tried to blow air though them and get no air through the bottom of the tees. hate to drill a hole and find they have not been cut/drilled prior to welding.
1 - 14 of 14 Posts
