To all those who have installed this Plug n Play system, does it really start up easier? Is it like a Japanese bike after installing? I was curious.
Last year?I'll let you know if I ever get around to installing the set I bought last year.
Sent from my SM-G960U using Tapatalk
My bike was starting to take a little longer than normal to start, I bought the wires but before I installed them I got ivans flash and for some reason that seemed to fix the slow start. Still plan on installing them when it gets warmerLast year?
But the cornbread is not cooking the bacon cuz the pigeons are all flying.It is better to for the oil pump to prime the engine a couple of times. 90% of engine wear is caused by lack of oil at startup.
I have no issues with the bike so far. Starts up well and running great so far. When I run it. Sits on the trickle most of the time.Keeping this separate:
If you like big cube bikes and have what it takes to ride it well, then the Warrior is at the top of the go-to list. There is nothing else like it. This community is just one witness to this fact. It's sometimes hard to discover all the pita things a prior owner did to the bike. But there's enough info here to help identify how EVERYTHING should be connected and adjusted. Everything. Everything. A first task should always be to set-up Everything in the bike's baseline. Its far easier and far smarter. Get the SYSTEM as right as you can. After that, make repairs needed.
Those cables are great. But they won't make your Warrior start better if other things are set-up badly.
It needs more though.@catchinganupshift yep brother I get that, you've got a righteous ride it's a very mean looking bike!
Me too. Maybe 2 years ago.I'll let you know if I ever get around to installing the set I bought last year.
