Check engine light please help.
8.2K views 6 replies 5 participants last post by  2NDWFE
So 2 Saturdays ago I picked up my bike from the shop. I had an oil change done as well as having a PCV and BAK installed and dyno tune. I rode the bike for a little after picking it up, then didn't ride it until last Friday. Filled up the tank with 93 octane gas and rode about 20 miles before the check engine light came on. From the time I picked it up until the light came on I had maybe 60 miles on the bike. It also started running a little sluggish and it sounded like the valves or lifters were tapping. I've asked some guys on the warrior fb page about this and I've been told a few things. Check the oil level. I'm told if it's cold and reads full then there is too much oil in it. Also to check the fuel dry break. And something about being able to check the code using the tach buttons but idk how to do that. Any and all help would be appreciated because if its a quick fix I can do myself that would be better than taking the bike back to the shop and waiting forever for it again. Thanks
#2 ·
The bike has two fuel dry-breaks. One is under the rider seat along the tank. The other is left side under where the stock left scoop is or was.
Unclick each. Spray a brief shot of WD40 into female half. Re-click gently until audible click is heard. Do both. Fuel will again flow from top tank to bottom tank.
If this fails then unbolt and gently lift tail of tank at seat and find the biggish rubber hose and push it aside so it no longer is squished by the installed top fuel tank. Less common but happens.
#4 ·
- PRESS & HOLD SELECT AND RESET BUTTONS WHILE TURNING KEY ON, CONTINUE TO HOLD BUTTONS FOR APPROXIMATELY 8 SECONDS
- DIAG APPEARS IN THE CLOCK AREA OF THE INSTRUMENT PANEL
- RELEASE BUTTONS, PRESS & HOLD SELECT AND RESET BUTTONS AGAIN FOR APPROXIMATELY 2 SECONDS
- DISCONNECT FUEL PUMP CONNECTOR - LOCATED UNDER THE LEFT REAR CORNER OF GAS TANK. FUEL LIGHT ON INSTRUMENT PANEL WILL FLASH, THIS IS OK.
- INSTRUMENT PANEL WILL DISPLAY:
CLOCK SECTION: DI 01 (THIS IS THE 1ST DIANOSTIC CHECK)
ODOMETER SECTION: A NUMBER, USUALLY 15-17 (THIS AREA SHOWS THE VALUE OF THE SENSOR)
PERFORMING SENSOR CHECKS
( SELECT BUTTON WILL SCROLL UP, RESET BUTTON WILL SCROLL DOWN THRU THE CHECKS )
- DI 01 - THROTTLE POSITION SENSOR: TWIST THROTTLE, VALUE = : CLOSED =15 - 20, OPEN = 95 - 100.
- DI 02 - ATMOSPHERIC PRESSURE SENSOR: VARIES DEPENDING ON ATMOS. PRESS FOR THE DAY
- DI 03 - AIR INTAKE PRESSURE SENSOR #1: VALUE = 10-200 MMHG
- DI 04- AIR INTAKE PRESSURE SENSOR #2: VALUE = 10-200 MMHG
- DI 05 - INTAKE TEMP: MEASURE WITH TEMP GAUGE, COMPARE TO VALUE ON DISPLAY
- DI 07 - SPEED SENSOR: VALUE = 0-999
- DI 08 - LEAN ANGLE CUT OFF SENSOR: VALUE = 0.4 - 1.4 VOLTS
- DI 09 - FUEL SYSTEM VOLTAGE: VALUE = 0 - 18.7 VOLTS (12 VOLTS NORMAL)
- DI 10 - OIL TEMP SENSOR: VALUE = -30 TO 200*C / -22 TO 392*F
- DI 11 - ENGINE TEMP SENSOR: VALUE = -30 TO 200*C / -22 TO 392*F
- DI 20 - SIDE STAND: VALUE = ON/OFF
- DI 21 - NEUTRAL SWITCH: VALUE = NEUTRAL - ON, IN GEAR - OFF
- DI 30 - IGNITION COIL #1: TURN ENGINE STOP SWITCH TO OFF THEN BACK ON. CHECK ENGINE LIGHT SHOULD FLASH 5 TIMES.
- DI 31 - IGNITION COIL #2: TURN ENGINE STOP SWITCH TO OFF THEN BACK ON. CHECK ENGINE LIGHT SHOULD FLASH 5 TIMES.
- DI 36 - INJECTOR #1: TURN ENGINE STOP SWITCH TO OFF THEN BACK ON. CHECK ENGINE LIGHT SHOULD FLASH 5 TIMES WITH A CLICKING SOUND.
- DI 37 - INJECTOR #2: TURN ENGINE STOP SWITCH TO OFF THEN BACK ON. CHECK ENGINE LIGHT SHOULD FLASH 5 TIMES WITH A CLICKING SOUND.
- DI 50 - FUEL SYSTEM RELAY: TURN ENGINE STOP SWITCH TO OFF THEN BACK ON. CHECK ENGINE LIGHT SHOULD FLASH 5 TIMES WITH A CLICKING SOUND.
- DI 52 - HEADLIGHT RELAY: TURN ENGINE STOP SWITCH TO OFF THEN BACK ON. CHECK ENGINE LIGHT SHOULD FLASH 5 TIMES WITH A CLICKING SOUND.
- DI 54 - LINEAR CONTROL VALVE: TURN ENGINE STOP SWITCH TO OFF THEN BACK ON. CHECK FOR ACTUATION (CYCLING) SOUND.
- DI 55 - DECOMPRESSION SOLENOID: TURN ENGINE STOP SWITCH TO OFF THEN BACK ON. CHECK FOR ACTUATION (CYCLING) SOUND.
- DI 60 - E2PROM: VALUE = 01 - 02 FOR CYLINDER MALFUNCTION. 00 = NO MALFUNTION.
- DI 61 - MALFUCTION HISTORY: VALUE = 11 TO 55, 00 = NO MALFUNTION.
- DI 62 - MALFUNTION HISTORY ERASE: 00 TO 21, 00 = NO MALFUNTION
TO ERASE HISTORY: TURN ENGINE STOP SWITCH TO OFF THEN BACK ON. DISPLAY SHOULD READ 00.
- DI 70 - CONTROL NMBER: DISPLAYS THE PROGRAM CONTROL NUMBER, VALUE = 00 - 255.
ENGINE CODES:
11 - NO SIGNAL RECEIVED FROM CYLINDER IDENTIFICATION SENSOR (CAM POSITION SENSOR)
12 - NO CRANK POSTION SIGNAL
13 - AIR INTAKE SENSOR #1 - OPEN/SHORT DETECTED
14 - INTAKE PRESSURE SENSOR #1 - PIPE CLOGGED OR THROTTLE POSITION SENSOR (TPS) STUCK
15 - TPS - OPEN/SHORT DETECTED
16 - STUCK TPS SENSOR
19 - SIDE STAND SWITCH - OPEN/SHORT DETECTED
20 - ATMOSPHERIC SENSOR VOLTAGE & AIR INTAKE PRESSURE SENSOR VOLTAGE DIFFER GREATLY
22 - AIR INTAKE TEMP SENSOR - OPEN/SHORT DETECTED
23 - ATMOSPHERIC SENSOR - OPEN/SHORT DETECTED
25 - AIR INTAKE PRESSURE SENSOR #2 - OPEN/SHORT DETECTED
26 - INTAKE PRESSURE SENSOR #2 - PIPE CLOGGED OR THROTTLE POSITION SENSOR (TPS) STUCK
27 - OIL TEMP SENSOR - OPEN/SHORT DETECTED
28 - ENGINE TEMP SENSOR - OPEN/SHORT DETECTED
29 - DECOMPRESSION SOLENIOD (THERMISTOR) - OPEN/SHORT DETECTED
30 - MOTORCYCLE HAS OVERTURNED
37 - FAULTY LINEAR CONTROL VALVE
38 - DECOMPRESSION SOLENOID - OPEN/SHORT DETECTED
41 - LEAN ANGLE CUT OFF SWITCH - OPEN/SHORT DETECTED
42 - NO NORMAL SIGNAL RECEIVED FROM SPEED SENSOR & OR NEUTRAL SWITCH OPEN/SHORTED
43 - ECU CAN NOT MONITOR BATTERY VOLTAGE - OPEN/SHORT DETECTED
50 - FAULTY ECU MEMORY
#5 ·
Been working too many hours. I re-read the OP.
So your check engine light came on, not the low fuel light? My bad.
The service manual has steps to read codes. Tap 'Technical Bits' in my sigpic and check those tabs for an e-copy.
Is the oil change shop a Yamaha shop?
Did you read how to check the oil level or did you watch that video in The Welcome Mat forum?
Did you buy gas at the usual gas station you frequent or at another name brand gas station? We can talk about octane later.
#7 ·
When you first turn on ignition switch, up top, it should give you a number, not the clock display... that us your code that turned on the MIL (malfunction indicator light.... check engine light). You can then use that code to see where your problem is. There may be more than one code so you'll have to go into the diag portion of the display and retrieve your code history. Once you fix your issue, you can go back into diag mode, back into history and then clear the history.
