electrical issue please help
1.2K views 6 replies 5 participants last post by  myzen
I installed the 4" risers today and when I did I removed the headlight for easier access. When I plugged everything back together and turned on the key the right front and rear turn signal are illuminated while the left is not. When I activate the turn signal switch on the handlebar, the left one works fine but the right one flashes real fast. I did no other modifications except add taller risers. Any ideas what I did or how to fix it?
#5 ·
Thank you for the help, I did have wires crossed. When I initially put it bach together I thought the two harneses should have one black wire and one blue. With your help I found out the two blues needed to be with the blue and two black wires with the black, now it works. Thanks again.
#7 ·
I am going to have to replace the brake lines. I routed them behind the triple trees right now and I do not like the way it looks. But for now it is ridable. As for the other cables, I did remove most of the guides with the exception to the ones on the handlebars. The clutch cable was tight, then the plastic guide popped off and now it is just fine. Other than that, there is no binding of any cables. I will be adding the SS lines in a week or two. Overall a pretty easy job to do.
