As stated, take the necessary precautions to protect your investment from any stray brake fluid or spills!
With your late model '07' bike I suggest the following
irect the brake fluid from the right frt caliper into a glass jar using surgical tubing at the bleeder screw. Tie the frt MC brake lever so that it is partially operated. Remove the banjo bolt at the MC and cover the end with a small sandwich bag and elastic band.
The brake fluid should run freely from the hose into the jar. Remove caliper banjo bolt and bag end. Repeat this procedure for the left caliper.
Rear brakes same procedure but wedge the brake pedal between the exhaust pipe to prevent loss of fluid from MC brake reservoir. Remember, you need to open the bleeder 1st before operating the pedal
I found gravity bleeding the rear brakes to be more tenuous after replacing the stock brake hose then was the frt!
It was necessary for me to loosen the rear MC (2-screws) and twist it in such a fashion so that the air could escape from the right angle portion of the new hose at the MC outlet. Essentially, I twisted it so that the angled end was vertical & sloped to release the air. I also dismounted and blocked the caliper piston and positioned it as low as possible with the bleeder screw pointing up.
If gravity bleeding is used just be sure that the air isn't trapped at the nose of the MC or any fitting. I always follow up with the typical/traditional pumping of the lever or pedal in unison w/the bleeder screw.
Up frt start with the furthest caliper 1st to remove the air…leaving the reservoir cover open or loose will help the fluid flow quicker. The position of the MC nose is critical to be successful with this procedure. Short stroking of the lever will remove the air from the banjo fitting if the MC is tilted w/the nose down and the fitting at a right angle.
This isn't rocket science, just remember that the air wants to rise so you need to provide the proper path [
] Investing in a
proper vacuum device is certainly quicker but isn't req'd IMO.
