Mods...Fitting 250 rear
13K views 30 replies 17 participants last post by  jpwarrior
So after careful cutting, sanding and grinding I am now finished fitting my new 250 rear Avon and new rim into the stock swingarm. It's not in there straight in there in this picture cause it's comin right back out. But wow....!
Insert Image:
35.34KB
Sorry I failed to take pics of the process.
Swingarm is now going to get powdercoated black again.
Then I'll fit it all together and move to the 21" front rim.
Whatta yall think?!
Gettin farther away from stock! [/emoticons/emotion-1.gif]
Insert Image:
32.7KB
#29 ·
The Metzler 240/40 @ 40psi doesn't flex 1/8" when mounted to a 18 x 8.5 weld-up Warrior wheel. I have a nickels worth of clearance, if that, on my DIY swingarm without any rubbing and well over 6000 miles and no chicken strip either [
Side wall flexure has a lot to do with tire construction as well as the wheel width and pressure IMO
quote:Originally posted by needawarrior
tires expand at the contact patch is true but when you go into a corner hard there is some sidewall deflection.if you have an 1/8" or less of clearance on both sides you will find rub marks on the inside of the swingarm because of deflection.
